QUOTE(aircooledtechguy @ Mar 6 2012, 09:30 PM)
AFAIK, the relay board is NOT weatherproof. That would preclude it from use in the engine bay of our cars. I would mount it under the seat with your ECU and run the wires through one of the Delphi connectors as others have suggested.
On my '67 VW Squareback, I have the relay board under the seat and only have the harness exposed to the elements.
You NEED the TPS. The MS ECU needs both MAP and a TPS to "triangulate" the engine's fuel requirements. Just like GPS needs 2 satellites to know where you are, the ECU needs both MAP and TPS to know what you need.
Consider EDIS or COP for ignition. Once you have the tunability that these offer, you will NEVER go back to a dizzy again. Dizzy's are just a compromise. . .
If you want an MSQ file that is close for a stock 2.0L motor, PM me.
I agree that a TPS should be used but, Bits racing offers a MS Partial kit that converts a flat six to MS EFI without the TPS. They just use the MAP. They say the difference is hardly measurable. A TPS is not hard to find though and is pretty cheap.
As far as the relay board, the stock 914 relay board should be fine. You have two 12v power outputs (one for the injectors and one to MS) and one Fuel Pump output to the MS (comes directly from the FP Relay and MS provides ground) and that should be all for fuel only. There is even an extra 12v out that would go to the Cold Start Valve that you can use as a switched 12v supply to the O2 sensor. If your using an IAC instead of the AAR then you can use the 12v supply from the AAR as a switched 12v line as well.
When you go to ignition control, then you may have to piggy back another 12v supply or come right off the fuel pump 12v.
I haven't finished tracing the schematics but I pretty much have it all in my head. I'd like to make a standard harness that can be duplicated but it's all theory and notes at the moment.
