QUOTE(James Adams @ Aug 4 2004, 01:21 PM)
No, you need a '69 or earlier 911 flywheel.
the 914.6 flywheel is 901.102.026.01 and has the timing marks in the correct place.
Stoddard has them new in stock (but bring money - they're $617.50) so they should be available through the dealer network. i think the hot setup may be to get one through Kennedy, maybe even with one of their tricko new clutches although a 2,2T won't stress the stocker much...
if you use an early 911 flywheel, be sure to transfer the Z1 and ignition timing mark to the new flywheel so it can be used to time the engine. this'd be a really good time to transfer all 3 TDC marks so they can be used for valve adjustments ...
