I read a Technical Article that stated to swap out a tail shifter for a side shifter, you needed a late model engine mount.
Is this true? If so, how late? my teener is a '72.
thx
ArtechnikA
Aug 5 2004, 08:19 AM
QUOTE(jr91472 @ Aug 5 2004, 06:13 AM)
late enough for the car to have had a side shifter ...
rhodyguy
Aug 5 2004, 08:54 AM
you will need a bar from a 73 or later. it has a large cast hole that the rod passes through. you are going to need the 2 brackets that bolt to the front of the block, 2 rubber mounts that go in between the brackets and the bar, and 2 of the solid outboard pieces that replace the earlier outboard style. plan on buying the replacement/adapter firewall bushing with the correct outside diameter for the early hole and the correct inside diameter for the later rod.
kevin
jr91472
Aug 5 2004, 01:44 PM
thanks rhodyguy,
I had not consider the point regarding the firewall bushing.
JR
