Remove the old 5 mph shocks, locate the holes from measurments taken from another pre-75 car, drill the required holes, obtain the correct type bolts, dog bone rubber spacers (4 required) spacers and bolt spacers/collars. You will need early type fog lights, unless you have the no light horn grills. You will also need to remove the spot welded u-channel on, 2 each end, that the late bumpers lock in, dress and paint. Its a days work to make it right. Worth it in my opinion.
