QUOTE(michaelmoo @ Aug 6 2004, 09:26 AM)
Has anyone changed there rear glass to the heated glass. Also does anyone have pictures of the heated rear glass.
yes. no.
you'll need additional wiring and connectors and a dash-mounted switch.
the original parts are very hard to come by.
some cars came with the wiring (in the main harness), some didn't.
there's a empty 2-prong connector on your relay-board where the wires from the glass plug into. (it's fused there too). if your main harness doesn't have the wire, you need to run one from your dash to the relay board.
i know brad has probably 5 heated rear windows in his shop.
Andy
