I have read that what ever you go with, make sure the gauge and the sender match. That makes sense. Further reading, I see that there is a long type that appears to work with the unique factory taco plate. The short model must work with the "home made" taco plate. I have already found that the unique plate can cost as much as $70 and I can make the home made one. Couple of home made versions: 1 welds a nut inside the plate and this one apparently just uses a nut inside the plate.
And the factory one also includes an extra cover plate to keep the cool breezes from the hot oil sender.
What are some thoughts about which is best, most reliable, doesn't leak, etc....?
Since my 75 1.8 just has a standard plate, how was the oil temp measured or was it?
