Brand new Stasis Tracksports (extra set of Street Sport springs)
Porsche Cayenne frt. calipers, x-drilled ML55 rotors with Hawk HPS pads, all new
B6S4 rear calipers, x-drilled rotors with Hawk HPS pads, all new
VMR V710 wheels 19x8.5 w/Kuhmo Ecsta 235/35/19 less then 8k miles on wheels and tires.
RS4 rear sway bar
LESS THEN 10K MILES ON THE ABOVE, AND LESS THEN 15K MILES ON EVERYTHING BELOW
Eurocode 2.0L short block, JE pistons, Scat Rods, Eurospec forged, knifedged lightweight crank
Ported and polished AMB head, with Ferrea SS valves, springs, and titanium retainers
Cat 3658 Cams
830cc injs.
Treadstone Cast SS manifold and Garrett 3582r .63 hotside,(has 3076 comp. housing to clear frame) full street boost (20psi) by ~4500rpm with a rev limit of 8500rpm Tune by Revo
Tial 38mm WG
AEB intake Manifold
OBX BOV
FMIC
Meth inj.w/dual nozzles
NEW less then 200 miles Southbend Custom 4 puck sprung hubbed clutch with an additional 800lbs of clamping force on the pressure plate and an 15 lb. steel flywheel.
Return style fuel system with adj. FP regulator and Walbro 255hp pump
034 street motor and trans mounts with a Neuspeed snub
JHM Short shifter
Shutt sport steering wheel
116k miles on body
Black leather
Heated seats
The body is silver in excellent condition
This car makes over 400 hp
Over $12000 in parts
The bad
Fuel pump went bad 2 weeks ago so the car does not start!
Call me at 914 482 0398
- it's NOT ok to contact this poster with services or other commercial interests
