Full Version: 914-6 enrichment lever
morph
basic question is the enrichment lever the same from a 914-6 the same in a early 911? the lever in front of the shifter for carbs.also does anyone have pictures of this set up ? they would like to share?
Eric_Shea
No pictures but I have a 914-6 and an early 911.
The 914-6 utilizes a rod that runs forward to a specially stamped accelerator pedal bracket. Pushing the lever forward positions the rod against the bracket and basically pushes down the accelerator pedal.
The 911 utilizes a nylon cam that pulls the accelerator cable forward as you lift up on the lever (if'n I recall proper).
morph
