Full Version: Engine Cross member Jack plates?
pete000
On my 1974 1.8 has these plates on the cross member mounts. Are they jack points? I do not see them in the parts diagrams. idea.gif
QUOTE(pete000 @ Nov 16 2011, 11:40 AM) *
Nope. Those look like the big washers that are supposed to be used on the transmission ears so the transmission bolts don't slide out of the mounts.
Btw., there was a thread here last week explaining why *not* to use the engine bar to jack up your car. Or the transmission for that matter ...
pete000
Looks like whoever had the engine out previous owner got mixed up.
I did not jack up the car using them, but they will be coming off now !
Figured they looked a bit odd there !
Thanks !
wingnut86
I'm afraid to ask.
You know not to get under the rear of the car without additional bracing, correct?
Not knowing how they mounted the tranny should be a safety concern now.
flash914
Those were used on the tail shift cars in the same spot. Maybe some one at one time put the car back together from a basket case like I did.
pete000
The trans has new Wevo blue mounts.
Have no clue how this got put together.
