QUOTE(Gearren @ Aug 8 2004, 05:41 PM)
could it just be that the carbs are not tuned properly.
yes.
did you change the oil before you fired it up? did it have any oil in it while it was stored?
did you drain the gas-tank prior to startup? did you replace the fuel-filter?
if the motor still had oil in it and you drained it, was there white sludge in the oil?
Andy
