The paint code (L32K) seems to be the same as for Ghias, so I suspect this page will do the trick: paintref.com
Skip
Series9
Nov 19 2011, 10:22 AM
I should always Google before I start a new thread like this.
I found the info.
Thanks.
Matt Romanowski
Nov 20 2011, 09:41 AM
As a warning - many of the PPG codes have been converted through a number of different paint lines and do not always match the original color very well. I had serious trouble matching Willow Green through PPG.
If you go to the PPG links on there (and below), then pick your color & go to their old documents, one or both of those should give the actual mix code. http://autocolorlibrary.com/
BTW the 914's used the VW Paint color codes, so both are the same paint/color, so it should be on one of the jpg docs on this page: http://autocolorlibrary.com/default.aspx
