QUOTE(J P Stein @ Nov 21 2011, 05:05 AM)
Static camber was set at -.5 front & rear....bias ply tires. I fooled around with toe quite a bit and ended up with 0 toe f & R. Toe out made the car too squirrely under heavy braking & corner entry....AX is a game of inches. 21mm T bars & 275 lb springs. Since one doesn't get many chances at a course (3 passes at SCCA), IMO making the car easy to drive all over the range of crap course designers throw at you......everything to long sweepers to 180 deg single cone pivot turns, tight spaced slaloms, wide spaced slaloms, variable length cone slaloms. Basic oversteer to help rotate the car...but not too much. Tire pressures were all we fooled with at an event. Got a bit carried away with lowering the rear in that second picture.....bout rolled the tire off the rim, oops. It scared the crap outta me when I saw that pic.
never went below 20 psi after that....19 in front.
22mm AR bar set half hard is enough to lift the inside front. On a butt smooth surface a lot stiffer/lower setup would be the cat's ass and all that flopping around would be gone. I drove a track set up 914 on our venue once. It was at least twice as stiff as mine & it was undriveable there.
My car carried only about 350 lbs on each front wheel. As you can see the total front weight often was transferred to the outer front (some went aft, of course)
The shocks were very soft in rebound & just stiff enough in jounce.....even then it would rattle your eyeballs....(literally) double vision on the rough patches.
Did I say our home venue is rough? A bad patch.This could be avoided...once ya knew it was there. The natural line took you there tho.
Hey JP,
I think I understand your setup: not much camber as the chassis is stiff enough not to roll much. Roll is the worst thing for a 914 as the loaded rear wheel toes-in
.100" for each 1 inch of compression.
I appreciate playing with toe can have some benefits: a little front toe-out is said to aid turn-in, but I found that anything more than 1/16" made the car so nervous there was NO relaxing on-track. The rear is another story: 0 toe is a great place to start, but some toe-out could help the car rotate. Of course, how much and when to make the adjustment will only work if you know you'll run a tight or high-speed course.
I'm in 100% agreement: a car that is easy to drive is a fast car.
Enjoy,
Terry
