I have some air trapped in my brakes and want to try the long tube method to purge. With the tubes in the resevoir and connected to each caliper nipple, I understand the idea of cracking each nippple open and pumping until the cows come come.
What puzzles me is the idea of injecting air back into the system using this method. Until the lines are full of fluid, won't you be sucking air on each pump of the brakes back throuh the nipple from the empty tubes?
I have a motive bleeder but can't seem to get all the air out. It takes a couple pumps to get a hard pedal.
New MC
All new rebuilt calipers, etc
Used the pedal pump and release method
Flushed a 1/2 gallon of fluid throuh the calipers
Rear vented to .004
Driven the car and repeated the bleeding with motive and two people
Yes, the front caliper nipples are pointed up
No speed bleeders
