QUOTE(Mark Henry @ Nov 27 2011, 08:49 AM)
Consider ourselves lucky, at least we have a economical source of CV's that only need a minor mod.
But it is my understanding that the heat treated metal does not drill well and these need to be milled. I have not tried to drill any of them but you can see color of the metal has changed, from the heat treating, all the way into the bolt holes.
Where did you get these from? do they offer them pre machined?
Eric at PMB Performance sells a kit with the machining do already for about $90.
Jim
From PMB Site:
"So... 914 CV joints are NLA (no longer available!). Here's what you do. Get this Type 1 kit (same CV joint) for a fraction of the price. We've machined the pin holes and done all the work for you. While the suppliers "stock" photo doesn't show the work, two opposing holes have been perfectly machined to accept the dowel pins. You simply transfer your pins to these CV's and bolt them on."
