QUOTE(nathansnathan @ Nov 28 2011, 06:13 AM)
QUOTE(bigkensteele @ Nov 27 2011, 09:30 PM)
Do NOT drill it out and run a tap through it. It is a tapered thread, and if you tap it, you will have a hard time sealing a new one.
It's actually a straight thread, though if it were tapered you could just tap it a little deeper if you did bugger up the thread. I'd try on of the square-shaped easy outs, they work a lot better than the twisty ones I think, after enlarging the hole with a drill- just don't go all the way through and chips will not get in.
WRONG!!!!!!! It is NOT a straight thread! I won't even begin to guess where you got this erroneous information, but it's now in the archives where it will confuse newbies until the end of time. It's 10mm fine tapered, which is functionally the same as 1/8" NPT. The correct switch will be tapered, as well, and will not use a gasket.
The Cap'n
