SOLD
I rebuilt this engine 3 years ago and ran it on the street and a bunch of DE events. I converted to a 6 last year and really don't have any use for this engine. Check my build thread link at the bottom of this post for some pictures. I'll get some more pictures and videos up later.
The Good:
- Keith Black 96mm pistons
- Webcam 86B cam
- Schaedek pump with properly clearanced cam gear
- Dual Weber IDF40's
- Rebuilt heads
- Resurfaced Flywheel
- Complete from fan shroud to flywheel and '74 engine bar. Ready to run, no tuning needed.
The not so Good:
- AA cylinders
- Some piston slap
I went with AA cylinders because of two previous very good experiences with them. This set was clearly cost reduced and had more piston to cylinder clearance than I was really happy with. The result is what sounds like knocking at certain RPMs. At one point, I disassembled the engine and replaced the rods and rod bearings thinking that was the problem, but the noise was still there.
Bottom line is that this is a solid engine with good power throughout the RPM range. There's roughly 10,000 miles on this engine.
$1500 plus shipping. Local pickup preferred, but I can palletize and ship if needed.
Thanks for looking!
