OK, here's part of a long story but bottom line is that the high temperature coating that Chris puts on the Tangerine headers may have saved my life & my car.
Huge fuel leak at speed on back straight at VIR was streaming fuel from the engine tin right down over the driver's side header. Got into the paddock unaware of the problem & pit lane worker was waving his hands behind me--"Shut off, disconnect battery--you're pouring fuel..."
As I exited the car & pushing up with my left hand on the sill it came up wet with gas--looked under the car & sure enough, steady stream of fuel pouring over the header pipe. Popped the engine lid & drivers side hell hole has 2 quarts of gas in it--full to the brim and overflowing--later discovered an errant cheese head screw with washer was perfectly blocking the drain hole.
OK, towed car off the pavement to the dirt in paddock & started investigating--injector o-ring on cylinder #2 was popped loose--more on this later with pics, but back to the point of this part of the story.
The point that the fuel was on the header is maybe 6 inches downstream from my EGT probe which was showing about 1300F at speed. Gasoline will auto-ignite at about 600F. I've noticed before that the coating on these headers really keeps the heat inside them compared to uncoated pipes. I'm speculating that it turned out to be a lifesaver for me in this case.
