QUOTE(underthetire @ Dec 3 2011, 04:51 PM)
Better double check then, the pertronics units I think need it to keep from overheating. The stock coils have it built in. Should be something on their website to measure the coil resistance to determin if it's needed or not.
Thanks,
I Ordered from Advance Auto a MSD .08 ohm Ballast Resistor. Should pick it up Tuesday and give it a try weather permitting. The MDS Blaster 2 Coil does not have an internal Ballast. It was on the car when I got it along with a MDS 5 Box and the Pertronix under the Dizzy Cap. So, According to what I've research the Ballast resistor isn't require if using the MSD 5 Unit, but I've disconnected the MSD 5 Unit and beleive it's defective.
Car runs better with just the Pertronixs and the MSD Blaster Coil.
I check the Pertronics instructions and it say if the coil is 1.5 Ohm use the resistor for normal applications, but not for racing. If the coil is 3.0 Ohms for normal applications remove the resistor. The MSD 2 Blaster coil is less then 1.5 Ohms so it won't hurt to try installing the Ballast Resistor to see if the engine runs OK,
Then when ready I'll plug the tach back in to coil negative pole and see what happens.
