QUOTE(rick 918-S @ Dec 5 2011, 06:48 AM)
What is the paint code?
I'm sure if this is your 4th 914 you know where to look but just incase, drivers side between the hinges on the A pillar.
Ahhh... I see why you ask.
I said the car was an "SE". From what I remember, maybe I got the term wrong, an SE just meant it has all the "cool" options like front/rear sway bars, center consoles, etc... Is there another term you use for this option package?
My apologies/mistake.
I crossed it out on my original post.
I think you thought I was claiming it is an LE... no it is not.
L3OE is the code. Bahia Red.
Also, I hope my "4th 914" comment didn't seem cocky... not my intent.
I had those cars from 1991 to 1995. Note: I was in High School until '93.
2 of which were worse than my current one (Hawaii rust). The 3rd one was my pride 'n joy. It was a 74 1.8, with big bore 96mm, all done correctly. GT flares, 916 nose, etc, etc... I'll try to scan some pics later (pics taken before digital cameras existed... LOL).
QUOTE(Richard Casto @ Dec 5 2011, 07:59 AM)
As Mike said above it could be a few different things internally.
But, if you provide some more info, we could try to debug it more before you open it up. With the side shifter, when in neutral, you should be able to move the shift rod on the side shift console in/out. Are you able to do this? If not, what motion works/doesn't work?
Richard
Thanks Richard. Yes, I am able to move the shift rod in/out.
