seanery
Aug 14 2004, 07:08 PM
I think we need a practice run for both the Poker Run and the Twisty Road Tour.
Actually, we'll need to tweek the TRT a bit. We need to find a stop for a potty break.
Who's ever interested say here. I know Doug is travelling this weekend, so after he gets back let's pick a date and time and do it (whoever wants to that is). You don't have to do this, I just want to make the offer in case you all do.
Engman
Aug 14 2004, 07:10 PM
Ok - I will try to be there. Maybe meet for lunch?
GaroldShaffer
Aug 14 2004, 08:12 PM
I would like to but my weekends are book for this month.
I'll leave this one up to you guys, I trust ya
Pnambic
Aug 14 2004, 10:11 PM
Like Garold, I'm pretty booked. And its looking less and less likely that I'll have the silver 914 running in time. Sean, Garold, what do you know about putting webers back together? Got a book on that I could borrow? I think all I need to do is put the webers back together, manufacture a crossbar linkage for them, plug it all together and turn the key. I just can't get the help I need. (My father in law has had a lot on his plate....not really his fault
seanery
Aug 14 2004, 10:25 PM
I don't have a book. I bet if you posted you needed one, someone would let you borrow one.
OOOHH, there may be a weber thingy in the downloads section.
Get the CB crossbar, it's pretty nice.
Doug Leggins
Aug 19 2004, 11:04 AM
I am available most weekends except 10/2, 10/3. Also available late afternoon early evening if that works.
Dan - what do you need to get your car ready?
Pnambic
Aug 20 2004, 05:20 PM
I think I have all the pieces to get the silver one running. I've just never rebuilt carbs before. I don't have an official cross bar, but I have parts that I can use to make one. Good enough to get it running and then I can get a better one later. Anyone got a pair of weber carbs I could borrow for a week or so for the FFC? (
I need a pan-handling smilie here)
Hmm...I wonder if I need to weld up that hole on the passenger side long first....its probably not even 4 inches square...
prolly not, but definitely on the gotta-do-soon list.
seanery
Aug 20 2004, 09:02 PM
I've got a welder now.
Pnambic
Aug 20 2004, 11:19 PM
but do you know how to use it?
You think I could drive this safely, temporarily?
I may take you up on the welding, if that was an offer....
seanery
Aug 20 2004, 11:45 PM
nice foam!
if you had it cut out with new metal I could weld it for you. (I think)
Engman
Aug 21 2004, 07:39 AM
Do a little more exploring in there before you drive it. Right now, you cannot tell how far the rust extends. Shoot some pics after you clean it up some. That will tell how bad it is and if you can drive it that far.
M
Doug Leggins
Aug 23 2004, 12:04 PM
I just might. I'll check into it. If it works out they might be Dellortos instead of Webers.
From the pics so far the rust/foam area looks strong enough but you should take a good look in the area to see if it is solid around the jack post area or if there is more foam. Foam - that's crazy!!!
Also check the right rear suspension console area to confirm that it is strong enough. Hopefully there is no foam in that area!
