QUOTE(SLITS @ Dec 6 2011, 09:14 AM)
No need to remove the boot from the fan housing .... you can disconnect it from the alternator.
I should have mentioned that. If you are just replacing your alternator, just loosen the clamp and the alternator will slide out. I was pulling everything apart and cleaning, so maybe a different situation.
