A couple of little things about my Pilot light install:
1/ The factory grommets were on my existing wiring, so I removed the cheap Pilot light grommets and re-drilled (and moved over) the holes larger for the factory grommets. I then had to re-paint the housing.
2/ I put connectors on the pilot lights (inside) so not to damage/cut the factory wiring connectors. I like to try to keep my factory wiring as intact as possible.
I still have to aim my lights better, when you get that far this will help:
http://www.autooptiks.com/aiming.htmlHave fun, Mark
P.S. the Pilot light's were $69 Canadian, I think they are about $45 USD.
