All,
Thanks for the help on the heater lever operation. I disconnected the battery and disassembled the lever, removed most of the parts and cleaned them up and removed 40 years of corrosion. Sir Andy, thanks for the warning on the wire, probably would have shorted something out if I pulled the lever with the battery connected.
With that said, hopefully these are my last questions.
1. Is the wire that is connected to the lever "hot" when the ignition is in accessory mode, or only when the engine is actually on? Can I use my 12V sensor (screwdriver looking thing with a bulb in it and a ground wire) to connect to the wire and an approriate ground and make sure I actually have power?
2. If it turns out that I can't verify that the wire is hot and I reassemble everything and the fan does not work with the lever up, do I look at the relay in the engine compartment?
3. If my fan motor is not working, can I verify by pulling the wires at the fan and connect directly to the battery and a ground and check that the fan works?
I know the fan does not add much air flow, I just feel compelled to tinker with it until it works....need to spend some time in the garage before it gets too cold...
