jetdriver
Dec 8 2011, 01:02 PM
I am completing a surface rust problem in the rear trunk area.
I am trying to replace the caulking which was removed
I have called Pelican which they didnt have a product currently.
Does anyone know what this product is or was?
Any application tips to make it match the original.
Many Thanks.
Jetdriver
jim_hoyland
Dec 8 2011, 01:55 PM
QUOTE(jetdriver @ Dec 8 2011, 11:02 AM)
Many Thanks.
Jetdriver
Tom,
See:
http://www.914world.com/bbs2/index.php?sho...hl=seam++sealerIf you do a search on
+seam +sealer, you will get a list of threads covering this topic.
McMark
Dec 8 2011, 02:18 PM
To apply it as original you need a special air powered application gun from Wurth or 3M. They allow you to adjust the spray pattern to match the original texture, then it's just a matter of application technique (speed, distance, etc).
sean_v8_914
Dec 9 2011, 09:23 AM
I use a semi leveling 2 part SEM seam sealer. once it starts to tack up (4minutes) i use a bath loofah sponge to simulate th texture. fooled PCA judges in Tucson, phoenix, LA and san diego. finding teh right size sponge holes was a challenge that required experimentation.
I was not able to get teh Wurth gun to match as well.
