jeffdon
Dec 9 2011, 01:52 PM
Where can i get the tiny spade connectors that the horn wire uses to attach to the wheel. I frickin broke mine clean off, and its broke in a way as to be tough to solder.
bandjoey
Dec 9 2011, 04:47 PM
I attached a ring connector to the wire, drilled a small hole, and screwed it down.
zonedoubt
Dec 9 2011, 05:19 PM
Mine broke off too. I cut a couple notches in the metal with a Dremel and bent it to make a little tab.
Drums66
Dec 9 2011, 06:09 PM
......Solder it!
(or any way you choose)
any electronic's store BTW
MartyYeoman
Dec 9 2011, 06:27 PM
Radio Shack has them.
