So this is the story. In June of 2010 I purchased a beautifully restored 1974 914 from which the prior owner had removed the engine. At that time I decided to undertake the process of converting the car to a 914-6.
I have spent the last year and a half accumulating the knowledge and parts to perform the conversion as listed below. I spent a great deal of time researching which were the best parts for this process and accumulating each of the pieces. I ended up with a 3 liter engine which I retrofitted to Weber carbs, and it is probably good for an honest 200 hp.
Recently however I've seen a lot of discussion about people putting Subaru engines in their cars. There was one gentleman in Arizona who's doing some pretty spectacular things with his conversions with Porsche Boxsters that have also caught my attention. Additionally, I have a friend with a 2005 STI who claims that with minor modifications he has 340 crank horsepower and full reliability. We then spent some time discussing the merits of a 2000 pound car with 340 hp, which is easily upgraded, as compared to the same car with a 200 hp engine, for which upgrades are fairly expensive.
So this has got me thinking about the direction of my project. Everything I have accumulated (aside from the engine which is very fresh) is brand-new but nothing has been installed yet. I have not welded in the engine mount nor have I installed the oil tank, the front cooler or ran any oil lines. Therefore, although everything is ready to go in I am not actually committed to this route. Up front I have cut some additional cooling holes but that's about it. I assume that would only be helpful if a radiator is going to be there anyhow.
What I have been contemplating is the possibility of selling everything that I have accumulated and re-engineering the project to accept a mildly modified EJ engine and purchase all of the necessary conversion parts for such a project. I have the feeling that the cost will be about the same, or even less using the Subaru parts. However, I wanted to run this past the great minds on this board to get your input as to the propriety of this change of direction.
My 901 transmission has recently been gone through and is in great shape. My concern is that the 901 would not be up to the task of a 340 hp engine and that perhaps the transmission would need to be changed as well. However, if I need to buy a conversion adapter for a Subaru anyhow perhaps the change to a different transmission would not be a big issue? I don't know much about the shift linkage issues though.
I haven't done much research on the Subaru conversion issue simply because I was so focused on the 914 six conversion, however, I plan to start reading more about the nuances of Subaru conversions.
So my question is this: Am I completely crazy for thinking about changing gears at this late stage of the game?
What do you think it would cost for a relatively fresh STI engine including the computer/engine management system and harness, the conversion adapters and a good transmission.
Aside from a radiator and the appropriate plumbing, what other unforeseen costs would I be facing the situation?
I'm not really worried about the value of the car because I don't think the 914-6 would have any great value as it is simply a clone and does not have real provenance. Plus I'm really more concerned about the fun factor in the car than it's resell value.
Here's a list of the parts I've accumulated:
914-6 conversion parts
Engine:
1979 3.0 liter with large 39mm port heads, upgraded to Carrera tensioners
Powder coat fan, shroud, valve covers
Yellow cad plating on carb linkage and fan pulley
Turbo valve covers, fins trimmed to clear trailing arms, powder coated
914-6 Sheet metal (not fiberglass)
914-6 engine oil cooler with AN fittings
Weber 40 IDA/manifolds/linkage, completely rebuilt and bench tested by Paul at Performance Oriented, K&N Filters and rain hats
Intake manifolds are glass beaded, port matched to the heads, brand new gaskets and phenolic spacers
Jerry Woods complete distributor rebuild
Magnecor Spark Plug wires, new plugs
New high torque starter
Cooling system:
Mazda RX-7 front oil cooler with AN fittings, dual Spal electric fans with thermo switch
Patrick Motorsports 914-6 oil tank with AN fittings
Mocal external thermostat
Conversion parts:
Rich Johnson engine conversion mount
MSDS 1 5/8 inch headers for 914-6 with ceramic coating
6 cyl tach - early style with silver button on needle
Kennedy conversion flywheel with Stage 2 clutch, new throw out bearing
Holley HP 125 Fuel pump, filter, Holley regulator, -6 AN fittings
MSD 6-AL Ignition box, MSD Blaster high vibration coil
I figure I probably have about $10,000 tied up into all the above parts, not counting my research and labor time. I suppose I could try to sell everything as a package or, alternatively, sell the engine separately and then sell the conversion parts as a package.
Thanks in advance for all of your constructive input into this decision process.
