Full Version: rear spring identification
sean_v8_914
while spring diameter may not be exact science , it can be used as a guide to help us figure out aprox spring rate.
here are some measurements I took from the stash of springs
12.88mm = 200#
11.88 = 180#
11.26mm = 165 progressive
10.8mm = 140#?
9.7mm = stock X#
stugray
Welt
43/92 SP100 10.7 mm (100#)
67253 SP180 11.7mm (180#)
Eibach
336767 080.250.0225 9.86mm (225#)
1000.250.0175 9.90mm (175#)
So it seems that you can tell with the weltmeisters, but not the Eibachs.
sean_v8_914
those eibachs would be teh 2.5" and 2.25" smaller type used on adjustable spring perches like ground control. your part number indicates 2.5"
stugray
Both Eibachs are 2.5" One I got from the PO is a 175# and the ones I just got from ground control are 225#
