This engine is compatible with all years of Porsche 914 & 1972-1978 VW vans.
VW Van motor is still installed. Engine can be started and driven. 1800cc flat 4 cylinder air cooled in a 1975 Van.
2 hrs. run time on overhaul including rings, rod, main, cam bearings, front & rear seals & more.
This is a long block from head to head WITHOUT ACCESSORIES such as flywheel, clutch disk, pressure plate, alternator, fuel injection, exhaust, cooling tin.
Those components are OFFERED SEPARATELY.
I will remove this listing once the engine is purchased....
Steve 7six0-six 28-six 218
Keywords; Volkswagon, Volkswagen, Vanagon, Camper, Porsche, 914, Van, Bus, Westfalia, Westy, 411, 412, 914 Porsche, 1800, 1.8L, trans, transmission, tranny, 091, 6 rib
- it's NOT ok to contact this poster with services or other commercial interests
