Full Version: 914 trans/911 engine connection question
LCOX
I have a 914 side shifter trans that I want to use with a 911 2.7 engine
which starter will I need, the 914 or 911 one
what about the flywheel and clutch. Thanx! L
Luke M
Use the 914-6 or early 911 2.0 lt flywheel with the six spring clutch disc.
You can run a 914 starter on those flywheels also. It all bolts up to your 914 trans.
Jeffs9146
914-6 Conversion Guide!
Cap'n Krusty
911s and 914s used the same starter through model year 1977.
The Cap'n
