Full Version: fuel line grommet substitution
type47
I'm installing SS fuel line (CFR product) and am asking what others are doing about the rubber grommets for the fuel lines at the rear bulkhead. The car was carbed and the small plastic line (return) was removed when I bought it. The grommets can be seen as #27 & 28 in the following diagram.
http://www.autoatlanta.com/porsche-parts/p...n=91435620200#a
being a CSOB, I'm looking for sources of grommets that "will do" as options to factory parts.
The small fuel line is 7.5mm and the hole (which may have been enlarged) is 15mm.
914.356.201.00 (still available but I have this one. The larger fuel line is installed) and 914.356.202.00 (NLA, this is the one I'm looking for). Lines are being installed in a '73 4732914137)
Jeffs9146
CFR sells these!
type47
hmmm... perfect. Shoulda looked there first since I have his SS lines ...
Also, the good Dr suggested Wurth and Winzer. The search is on ...
BKLA
save yourself the headache --- buy Chris' grommets!
