Full Version: Oil Return Tubes
Jaymann
I have a small oil leak,It is coming from the oil return tubes.How involved is it to change them out??Are there any parts kits for this???Any help is appriciated.Thanks and Merry Christmass Jaymann from PA
IronHillRestorations
This is a 6 right? There's two options, pull the engine and pull the cam towers, or install the collapsible oil return tubes.
Jayson - I think you mean pushrod tubes. Unless your 4 has overhead cams.
luskesq
It would be helpful to know what kind of engine you have, a six or a 4. Depending, it could have either push rod tubes or oil return tubes. In this case, size makes a difference.
Keith
Jaymann
This car is a 75 and has a bone stock 4 cyl 1.8L motor.Jaymann
luskesq
Then Mepstein is correct, push rod tubes. Replacement is fairly simple and inexpensive. You need two seals per tube (large & small). Go to the Pelican site under Technical Articles and they have a fairly decent discussion on how to do it. If you search this site I'm sure you'll find further comment.
Have fun and good luck.
Keith
