QUOTE(shuie @ Dec 17 2011, 01:12 PM)
QUOTE(SirAndy @ Dec 17 2011, 12:31 PM)
Since it's normally not the tube itself that breaks, i'd go with a metal clamp around it in the front that is welded to the tunnel, a big washer around it in the rear to support the sheetmetal where the tube goes through the firewall and maybe another clamp in the middle where it goes through the little brace.
The tube is broken at the firewall. The firewall is completely mangled in this area. I can't imagine what would even cause this, I just assumed it was pretty common. pics...
If you can replace the pans, or have someone that can, then you can do the tube repair.
The bulkhead attachment fails after the forward mounts fail.
The fuel lines are already out which is very good. Carefully remove the tube from tunnel completely. Repair/weld the bulkhead cracks leaving a suitable hole in the right location for the tube. Carefully grind all attachment remnants from tube. Weld tube through suitable washer about 3/4" from end.
Weld washer end to inside of bulkhead. Fabricate suitable straps for forward attachments and weld. Walla !!!
