I found a ruptured fuel line at one of the injectors (after I leaked half a tank of fuel in three blocks of driving, I can't believe I still have a car to talk about!) When I returned home, I briefly started the car to inspect, and it started fine. After doing the repair, the car won't start. I also don't hear the noise that usually came on with the key in the "on" position, I imagine that's the fuel pump? I'm sure that the fuel lines have some air in them after fixing the problem, although I'm concerned that something else went wrong because of the leak....
By the way, when the line ruptured, the idle went to about 2300 rpm, any thoughts on this, did the system sense low pressure and react with a higher idle? This was my inagural ride by the way, I now own the '75 red beauty with the luggage rack that George had for sale on this website.
