Full Version: what did you do to your 914 today
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337
mrbubblehead
i just wanted to start a thread to see what you guys do day to day on your cars.
i'll start,
about a month ago, i pulled my engine and trans to put in a new clutch. had the flywheel lightened and resurfaced. but what i didnt know is that i had to shim the little ball that the clutch arm rides on, after a resurfacing. so guess what i did today?
yup, pulled the trans and put an extra washer under the ball. you have to goop up both washers to get it to seal because the threaded hole goes all the way thru to the inside of the trans. i also replaced the plastic cup that the ball rides in. the throwout bearing and its little plastic blocks were fine so i buttoned every thing back up. 5 hours total. i think this has been the cheapest repair yet on my car. $2.75 for the little plastic cup.
what did you do to your 914 today?
racerbvd
ellisor3
I put a new fan belt on my 3.2. What a suck fest. No way to get both hands near the pulley. When I was done my arms felt like Stretch Armstrong.
shuie
cut out my floors
windforfun
Q-tipped its ears.
Gustl
yesterday I put my original leather steering wheel out of the car and replaced it with a newly leather covered one on a 30 mm longer hub (that gives me more leg space; I'm 6 ft 3")
today I will put out the "very custom" permatune installation out of the car and replace it with the original and newly rebuilt Bosch HKZ
gendent
I drove it to Costco, and back. Usually a 15 minute drive turned into 90 minutes. The long way home. No repairs. No break down. All back roads and no traffic. I did once worry I should be doing something else, but I got over that. Maybe tomorrow I will actually repair something.
Bob L.
I put the bumperetts back on the front and began removing the fuel system for cleaning.
Gendent: Sounds like a thorough test drive and shake down. you should be proud. biggrin.gif
PancakePorsche
Welded in Autopower roll cage, installed repainted fuel tank. Ready for track in two more weeks !!
cwpeden
Started it, wamred it up, turned it off. Then wished I had more time to fix the brakes.
Dumped half the res. of brake fluid on the floor of the carport for no apparent reason. Right off the master cylinder. Figure its the stupid hard lines from the res. They were a !@#!@ to get in.....or was it just me?
infraredcalvin
QUOTE(PancakePorsche @ Dec 17 2011, 11:29 PM) *
Would you mind starting a thread with pics on this one? I have a stable energies bolt in cage that I have an idea how it goes in, but would like to see others' solutions.
Sorry to hijack, back to the topic... I went to the shop and wished my baby a merry Xmas, hopefully Santa will bring some tools (a welder) so I can start spending some quality time again...
etcmss
Prep the front suspension for removal..down to the last 2 bolts. out it comes
bulitt
Picked up a fresh 327 SBC from a Nascar Mechanic. Xmas present for my 914.
Bored .060 over = 338 c.i. @ 330hp, Hi rev cam, roller rockers, etc. !
Phoenix-MN
No words needed shades.gif and yes, it's cold in the garage...
914itis
I started to reassemble the engine. Installing the thins , cleaned fan shroud
BuddyV
I replaced my 180 rear springs with 140s yesterday.
gary gartner
I will dust him off, clean up and get reaady for the SoCal Hangover run
That is all Folks
MrHyde
Finished welding a few touchups on the rear floor pan top-side..
Welded in the Tangerine racing rear inner suspension ear reinforcements.. Then ground the welds and rattle-can primer.
Then started taking apart one of the trailing arms.. got the calliper, rotor, shock/spring, dust shield off. Then started looking on here for an easier way to get the hub and bearing out.
Next I have to deep fry a turkey for about 8-10 people tonight.
Oh.. and it snowed a bit.... not enough to break out my snowboard, but its starting to feel like Christmas
mrbubblehead
stugray
Finished cleaning the last of my parts fro my Dual Weber rebuild in the ultra-sonic parts washer.
Touching up roll cage & reinstall after all new interior.
Replaced seat rails with race adjustable & grade 8 bolts.
Stripped & repainted the hellhole from PO's silicone mess.
Repainting the rear firewall engine side.
mrbubblehead
QUOTE(stugray @ Dec 18 2011, 12:13 PM) *
what type of ultra sonic parts washer do you have? where did you get it?
warpig
Decided to sell mine today hissyfit.gif Took it for a ride to drop toys for the Tijuana Toy run with the top off. cheer.gif Got rained on on the way home, it was nice and sunny when I left so left the top in the garage. confused24.gif
1988Hawk
Put in new turn signal and washer stalks. Pressured up the washer, no leaks.
Jim
hot_shoe914
I drove the LE to pick up lunch at my favorite Mexican place and am about to drive it to the gym for my workout. Will probably start Christine up and drive her around the neighborhood.
JawjaPorsche
Drove it to church then did some detailing this afternoon.
scott_in_nh
Let's see it is 25F but sunny in NH....
To it? nothing
For it? The garage crap was encroaching on its space so I organized and did some cleaning
For Me? What else I drove her to the beach!
Lou W
I moved mine into a storage unit along with all her parts in preperation for a trip to Colorado to her new home. I'm sorry to see her go, but I'm excited to see her going to a great home and put back together. smile.gif
euro911
Nothing today, but Milt (aka: Zeke) came by the shop yesterday to size up some metal repairs in the engine compartment on my '75 (needs new engine self and battery tray)
dirk9141973
piratenanner.gif Got it out of storage added qt oil drove it 20 miles and put back in storage for few months great day!!!!
FourBlades
Bled my front brakes after tightening up the gland nut on the driver side shock.
Both sides have loosened in just over a year to the point they were clunking over bumps. Used a little loctite this time and a big pipe wrench to tighten it.
John
malcolm2
QUOTE(mrbubblehead @ Dec 17 2011, 08:07 PM) *
i'll start,
I sat at the kitchen table and measured and cut my push-rods.....then installed the tips, while watching football and drinking beer. beer3.gif I wish I could move the engine into the kitchen and finish it. chowtime.gif Much nicer place to work. Believe it or not, that took about 1-1/2 football games. I measured 3 or 4 times then started cutting with my tube cutter which is a very slow process....ROUND AND ROUND AND ROUND. Then file and measure some more.
stugray
mrbubblehead,
"what type of ultra sonic parts washer do you have? where did you get it?"
http://www.harborfreight.com/25-liter-ultr...aner-95563.html
I have used water, HFE-7100 (dont ask), and denatured alcohol all in it with great results.
Stu
euro911
WTF.gif ... the regular price has shot up to $90.?
I bought the same U/S cleaner from HF a couple of years ago for only $60.
All the Chinese shit is starting to increase in price and timed to coincide with the fact that we no longer manufacture anything here.
Did anybody else see this coming?
porschefile2010
Mines in bits. Blew the head at #1 cylinder-found it was 103mm bore so going back to 96mm. So new cylinders/pistons and heads.
Found a CB 1.7 case so took it down today to be crack tested dipped and cleaned ready for a rebuild. Now hoping to be going next summer-maybe!
Never give up!
513mugsy
Measured up another Porsche for a possible suspension transplant! Looks like it will work from the measurements, and soon a new build thread should start. shades.gif
bulitt
QUOTE(euro911 @ Dec 19 2011, 01:20 AM) *
Been going on for several years. But you can still catch the deals. What cracks me up is they will list the same tool several times in their flyer for different prices??? So you can easily pay 10% more or less. Also, the stores don't know what the other foot is doing- the internet will list a sale price and the store won't list it reduced until you call them on it.
ellisor3
Nope, we are selling them usless bonds andy paying with useless currency anyway, they can raise the price to whatever they want. flag.gif
DRPHIL914
yesterday-
I replaced my center console panals with burled wood finish and a cup holder for my "coffee" ! - tired of it spilling- to match my doors. - I have to drill the holes for the Gauges , and will be installing a A/F ratio meter in Slot #3,
next up- going to do the dash as well, and hoping to get my fresh air blower going next- it no work- confused24.gif -
Phil
tradisrad
I did nothing to my 914 as my subaru decided to break it's fromt sway bar as I backed into the driveway! Hopefully I'll get my Konig seats this week and put them in next weekend.
m170seeker
I drove all ogver town Christmas shopping. Loaded the front and rear truncks with stuff. It was really fun.
Andyrew
QUOTE(tradisrad @ Dec 19 2011, 08:05 AM) *
Say whaaat?
Broken bar or end links?
tradisrad
QUOTE(Andyrew @ Dec 19 2011, 08:40 AM) *
Say whaaat?
The Subaru sway bar broke. I was able to find a new one at Pick & Pull. See here:
mrbubblehead
wow tradisrad, thats pretty crazy. luckily it happened in the driveway.
i was able to take my car out this morning on my 20 mile test loop. and it is shifting perfectly! driving.gif YEAH!
what a difference new bushings, new clutch disc, and an adjusted shifter makes. almost as smooth as one of my vws. i wonder if a cable shifter system would make it any better? or is this just the way the internals are designed? and its as good as its gonna get?
Bob L.
QUOTE(Philip W. @ Dec 19 2011, 09:41 AM) *
yesterday-
Phil
Nice wood panels. What kind of wood?
I plan on doing some wood trim in mine as well. I've seen some really nice stuff.
struckn
Turned the Key to On and Fuel pump kicked in, EM Brake Light Flashed, Oil and Temp Light came on. Turned key to start and heard a click and everything went dead, tried Start again and nothing. Waited ten minutes and it did the same thing. Disconnected the Positive battery cable and removed the yellow tack wire from the Negative terminal at the coil, reconnected the Battery and she fired up and ran. Backed out of the garage and saw oil dripping from the Oil Filter. Put it up on ramps and took a oil filter wrench and gave it a 1/4 of a turn to snug it up. Better but still dripping. Coming down from above the filter. Only leaks when running. Drove around to my other garage and parked it for winter storage. Going to look for a good repair shop after Holiday and Income Taxes in the Spring and get everything fixed.
type47
QUOTE(struckn @ Dec 19 2011, 12:50 PM) *
Turned the Key to On and Fuel pump ... and Income Taxes in the Spring and get everything fixed.
Zach and Joe Sayre are in your area if you need a hand (hmmm, it's easy to volunteer someone else to help biggrin.gif )
I finished the install of CFR SS fuel lines today after I received some parts from Tangerine. One "easy" job and I did it alone ('course the car has the engine out and is up on jack stands so that helped)
boogie_man
Worked all night long in the hell hole area....rust free and proud to be beer3.gif
DblDog
OK, it was last Friday...after WAY too long, I'm back on the road. Picked it from Mark at Original Customs...its a 72 with a used 73 1.7 and a De Bernardi enhanced side shift conversion...it shifts like butter! Now the fun begins...again.
BTW, I bought it in May of 72...brand new.
SLITS
I looked at it.
I started up the six and heated it up.
I went home.
Krieger
Bought her parts! Oil tank seals/spacer, spark plug wires, oil lines/fittings, carpet.
Invision Power Board © 2001-2024 Invision Power Services, Inc.
