majkos1
May 20 2018, 04:22 PM
QUOTE(marksteinhilber @ May 20 2018, 04:07 PM)
QUOTE(ndfrigi @ May 20 2018, 02:59 PM)
QUOTE(majkos1 @ May 20 2018, 02:05 PM)
I've practice on five doors before doing this....
Click to view attachmentI believed inside the door has a factory welded screw and just need to drill it if you wanted to add right door side mirror.
True, two easy ways. Drill up thru welded nut inside the door with a small drill to mak a pilot hole. Choose a size just smaller than the I’d of the threads. Then drill your clearance hole from a be outside. Second way is to use an ice pick from the inside to make a small center punch mark from the inside. Then centerpunch from the outside and drill the clearance hole till you just reach the nut. Viola!
That's what I did on first door.
Drill from inside.
Key trick is Center punch!
The door skin is thinner than the welded plate underneath.
If you locate the hole just right,creates a dimple.
Hence my pic.
majkos1
May 20 2018, 04:26 PM
First door,
drilling out the holes,
I like the center punch idea from here too!
Click to view attachmentClick to view attachment
914 Ranch
May 20 2018, 05:41 PM
Working on her tow vehicle. Putting insulation in and getting it street ready.
914 Ranch
May 20 2018, 05:43 PM
Big Blu...The Elephantah...
Mueller
May 21 2018, 10:00 AM
On Sunday we drove up to Vacaville, CA for a Cars & Coffee and hang out with Dominic, he brought his original signal orange 914-6 and his 550 Spyder replica/tribute.
Afterwards we (my twins and I) headed to his house and then I got to a chance to drive the 550 for about 10 minutes up some twisties and along some nice country back roads. Super fun car.
Getting in and out of it sure is a challenge. Thanks again Dominic.
ndfrigi
May 21 2018, 10:06 AM
QUOTE(914 Ranch @ May 20 2018, 04:41 PM)
Click to view attachmentSir Joe,
the view from rear facing your front cockpit of your trailer looks like a 914 seat. Is that intentional designing it?
914fahrer
May 21 2018, 11:19 AM
I polished my front Fender
ValcoOscar
May 21 2018, 11:33 AM
I received 4 more 914 models from member ChicagoPete.
All 1/43 scale GT's
Thank you...
Click to view attachment Click to view attachment
JFG
May 21 2018, 01:21 PM
For some reason the fuel pipe union at the tank started seeping. I was using an aluminium washer at that point. I bought some copper crush washers but one size was too small for the tank hole, the other size was right for the tank hole but too big for the pipe and would not tighten squarely. Third option was a teflon washer. This has worked but when slipping the rubber fuel hose on i loosened the nut!! After a cool down i got back to it and managed to get an adjustable spanner in to retighten. Fingers crossed it's fine tomorrow.
It's time to get started on the door cards. They were cut roughly for speakers and had been wet in the past which distorted them, the worst being around the speaker holes.
I filled the holes with hardboard and fibreglass on the weekend which enabled me to get the foam padding stuck down. Then it rained and i packed up for the night.
forrestkhaag
May 21 2018, 05:25 PM
what did I do with the 914 today?........ NOTHING!
i dropped off my carbs to the local Weber Guru and will await their return with corrected butterfly's, secondary venturi's and a few other slight modification in an attempt to get a reliable idle from warm to hot engine conditions. General interest pictures.........
JFG
May 22 2018, 12:08 AM
Woke up to the smell of petrol!!
euro911
May 22 2018, 01:14 PM
Lookin' good there, old timer
I'm in Buckeye for a few days, will be in Payson for the month of June, iffin' you want to stop by
euro911
May 22 2018, 02:25 PM
QUOTE(ValcoOscar @ May 20 2018, 06:45 AM)
Eddy and I met up with Jerry for a morning drive.
Two V8's and my black 2.0 74
Click to view attachmentLooks like Jerry bought Doug's old car? (mittelmotor)
StratPlayer
May 22 2018, 02:32 PM
Car is at PMB, things that are being done to the car. New cv joint drivers side, new hood springs, new 914 rubber led headlight bulbs, new 914 rubber plastic backpad being redone with new vinyl and foam, new rear rotors, some electrical work also being done.
ValcoOscar
May 22 2018, 02:33 PM
QUOTE(euro911 @ May 22 2018, 01:25 PM)
Yes...that is correct. Nicely put together.
anderssj
May 24 2018, 08:36 PM
Started reworking my old set of Pedrinis...a light bead blast, then prime, wet sand, and paint. Fingers crossed.
After the blast:
Maltese Falcon
May 24 2018, 11:37 PM
Pre-fitting the Engine block mounts on the 9148-gtt , this is the Right side which is tightly packaged near the outboard dry sump oil pump
cali914
May 25 2018, 12:15 AM
added the new led brake lights and turn signals from spoke works great product. Installation was a breeze.
falcor75
May 25 2018, 03:34 AM
My new rear euro taillight lenses doesnt fit very well....
JawjaPorsche
May 25 2018, 04:14 AM
This a common problem with replacement lens.
I found some small diameter rubber tubing and used it to fill the gap. Not perfect but works for me.
QUOTE(falcor75 @ May 25 2018, 05:34 AM)
maf914
May 25 2018, 07:57 AM
QUOTE(ValcoOscar @ May 21 2018, 09:33 AM)
All 1/43 scale GT's
Thank you...
Click to view attachment Click to view attachmentOscar, Thanks for the photos. Could you indicate the manufacturer(s) of those four models? Thanks.
TravisNeff
May 26 2018, 06:46 PM
Trunk is in.
warpig
May 27 2018, 12:32 AM
bob's project
May 29 2018, 09:56 AM
I put in an new throttle cable from Porsche. Much nicer than the GEMO one I had also bought.
It is nice to have a smooth throttle actions now.
The old and potentially original cable had sawed through the plastic sheath.
This was not as hard a job as I was expecting but I did take the console out of my car for not reason.
JFG
May 30 2018, 02:17 PM
Tonight I removed the Speedo drive and put new seals in there. Only to discover I may need to do the gear selector shaft also.
I've had no end of trouble painting the front bumper. There was always a reaction in the paint but in different places. I painted them orange first but changed my mind and have put them back to black. The rear bumper is ready to refit. The front one had a small reaction again in one place. After a chat with one of my customers I now have a different, tough, paint to use.
Hopefully tomorrow I will have that done finally.
budk
May 30 2018, 04:27 PM
I got another one delivered .....
Click to view attachment Click to view attachment... with lots of extra parts including A/C !
jcambo7
May 30 2018, 10:38 PM
RickS
May 31 2018, 08:27 AM
Set a personal best going up my local hill climb, and celebrated when I got home by tightening the heater lever assembly which would not stay up. Must be an age thing.
bob's project
May 31 2018, 05:55 PM
I just did a rear window reseal, Fixed my door light switches, and now cutting new sound pads for under my carpet. And, added to my list of parts to order some day of course.
I think I now have every functional issue dealt with. Time to enjoy until I do a full resto possibly this winter. Knees willing.
mlindner
Jun 1 2018, 06:33 AM
Finished my 914-6 inner fender liners.......Mark
Went for a quick ride before the storms rolled in.....
RickS
Jun 2 2018, 08:09 PM
Took it to a German car show. Stopped on the way back and took a pic or two
RickS
Jun 2 2018, 08:10 PM
Mueller
Jun 2 2018, 10:10 PM
QUOTE(RickS @ Jun 2 2018, 07:10 PM)
what a beauty!
marksteinhilber
Jun 2 2018, 10:50 PM
Washed it, took the top off and took my kids for a ride.
914fahrer
Jun 3 2018, 09:57 AM
After a lot of wet sanding i polished my rear fender .
914_7T3
Jun 3 2018, 10:09 AM
QUOTE(914fahrer @ Jun 3 2018, 08:57 AM)
Click to view attachment Click to view attachmentThat looks great!
lonewolfe
Jun 3 2018, 11:19 AM
QUOTE(mlindner @ Jun 1 2018, 04:33 AM)
Click to view attachmentAre these the fender liners that 914rubber.com sells?
sb914
Jun 3 2018, 12:02 PM
Jetsetsurfshop
Jun 3 2018, 12:44 PM
mlindner
Jun 3 2018, 01:00 PM
lonewolfe, no. 914rubber are made for standard fenders. I made these for the GT fenders. Much wider and are full fender liner. Thanks, Mark
I painted my car a while ago and although good there were a few imperfections. During the rebuild a few more imperfections have been added. Today i corrected most of those imperfections and keyed the whole car for a final blow over. Hopefully i can get it painted next weekend.
Although it's the 70th anniversary bash at my local porsche dealer on saturday so i'll have to do it all on sunday.
After replacing the speedo drive seals this week there was a stench of transmission oil in the garage but thankfully no leak. Sense of smell must be more sensitive than normal.
So so close to being road legal!!!
burton73
Jun 3 2018, 02:06 PM
QUOTE(Jetsetsurfshop @ Jun 3 2018, 11:44 AM)
Found this today.
PO removed the engine number????
Not a good thing.
If I was the law I would want that x-rayed. The stamping from the factory leaves an impression deeper than what they scraped. You never should have shown this to anyone. Well when it’s in your car it will not be able to be seen but WTF. Is that the engine that was in my 73 911s that got ripped off 35 years ago 500 miles after a full rebuild?
Bob B
Jun 3 2018, 02:17 PM
QUOTE(burton73 @ Jun 3 2018, 04:06 PM)
Found this today.
Not a good thing.
Bob B
Jetsetsurfshop
Jun 3 2018, 02:21 PM
QUOTE(burton73 @ Jun 3 2018, 12:06 PM)
Found this today.
Not a good thing.
Bob B
I'm not stoked on it either. Its a bummer.
The engine has been in my storage for about 10 years. Before that my dads friend owned it for about 15-20 years. He was going to use the engine for an airboat.
I figured I saved it.
Whatever.....
Jun 3 2018, 07:25 PM
eric9144
Jun 4 2018, 12:01 AM
Changed back to an LE type front dam, have had the flex dam on for the past 15 years or so, so it’s a nice change. While I was in there I swapped the fog bulbs for LEDs and cleaned the lenses
falcor75
Jun 4 2018, 12:41 AM
What type of leds are you running in the foglights?
eric9144
Jun 4 2018, 08:20 AM
QUOTE(falcor75 @ Jun 3 2018, 11:41 PM)
They were hard to find, I only wanted “plug and play” and no one makes that bulb type except for a vintage led guy in Australia (would have to dig to find his info)
Here are the bulbs:
falcor75
Jun 4 2018, 08:31 AM
Cool I've been looking everywhere for a ba20s led bulb but havnt found it.
