QUOTE(cwpeden @ Dec 18 2011, 02:42 AM)
Started it, wamred it up, turned it off. Then wished I had more time to fix the brakes.
Dumped half the res. of brake fluid on the floor of the carport for no apparent reason. Right off the master cylinder. Figure its the stupid hard lines from the res. They were a !@#!@ to get in.....or was it just me?
Not you alone - me too,,,,,,,the installation of a 914 MC is an absolute pain. On another post I was told by one of the 20+ year members that you HAVE to have the washers in the MC or it will not work right or bleed right or anything right......washers, WHAT WASHERS! Turns out that there are indeed washers and that the OEM people provided EVERYTHING but the washers.......sigh.
They sit UNDER the rubber thingies that the two plastic lines are inserted into.
CTC911CTC
