Took the car out for a summer drive / it was a balmy 109 so it was quite comfortable. Think about that for a minute. One's oil doesn't have to warm up. Bearing grease is fully lubed and pliable. Tranny gear oil is supple and all gears hit on targetsd without the "winter crunch" of cold gearbox juices.
On the down side, there are no other 911's or 914-6 versions on the road as most of the locals have their rides in mothballs........
One question looms ever present: When I elect to fire up the little beast after a few weeks of inactivity, it takes many many revs to get to oil pressure and even then, a few more seconds of rev to get the thing to come to life. Is this "normal" for a 6 with front oil cooler and stock 914-6 oil tank etc.
The Clewett crank fire ignition system is flawless once the oil pressure gauge pumps up but before that, many seconds of rev is required to make life where there was none.????
I am not sure if this is normal procedure........
just for interest, an old photo or two....... but maybe a good one or two...
Steve's car in the lead at 90+_..... YES!
Could it be that your oil tank is empty after weeks of standing from gravity pulling the oil out of it into the engine. Thus, the oil pump is sucking air until the scavenger side of the pump has put some oil back into the tank which then feeds the high pressure side of the pump?
