saigon71
Dec 6 2019, 04:39 PM
QUOTE(BeatNavy @ Dec 6 2019, 07:36 AM)
QUOTE(saigon71 @ Dec 5 2019, 09:33 PM)
Drove to the office on Wednesday before realizing they had salted the roads.
That's very pretty Bob -- nice pics!
I'm now a disciple of your salty road philosophy. Fortunately, they haven't laid it down here yet this year.
It's always a sad day when the teener goes into winter hibernation.
FlacaProductions
Dec 6 2019, 08:57 PM
new top seals - both horizontal ones and the fuzzy one around the back....my fingers hurt!
AZBanks
Dec 6 2019, 09:49 PM
Finally got it registered and got plates on it. Drove it all over with the top off.
Saigon71
Beautiful car. Bring it down to Arizona and you can drive it all winter. We need more green 914's in Arizona.
Jett,
You can bring yours as well. It's not the same green but it is gorgeous.
North Coast Jim
Dec 7 2019, 08:54 AM
Getting to the end point on the Tangerine Racing remote Oil cooler install. Well engineered and it looks as if it will solve all of my high temp conditions noted this last Summer OR maybe it was a mis-calibrated oil temp sender. In any case I'm now committed.
Had to remove all of the original thermostat/cooling items such as the flappers, thermostat bellows with cable and oil cooler. The Passenger side cooling path has been cleaned up and will now push the same volume of air as the drivers side. No more higher temps on the passenger side due to oil cooler placement. Yes the engine had to be removed and I took this time to adjust valves and clean up some oil leak areas.
Remote system incorporates a thermostat in the oil network so warmup is quick and controlled. Also includes a fan to force air over and thru the cooler.
Need to finish up with the wiring and oil lines and of course top off the cooler before engine start later today.
Click to view attachment Click to view attachment
DRPHIL914
Dec 7 2019, 09:40 AM
Installed my SPOKE fog lights and now at a local car show!!!
Jett
Dec 7 2019, 09:56 AM
QUOTE(AZBanks @ Dec 6 2019, 07:49 PM)
Saigon71
Jett,
Arizona and sun sound like good ideas
btw. I might have a set of re-chromed (from G-Car) foglight grills, if you are looking.
DRPHIL914
Dec 7 2019, 12:44 PM
Lots of comments on the 914 and our 50th!! But more questions about what is. 914RS!
sb914
Dec 7 2019, 01:04 PM
Rs =‘Really sweet in your case !
mb911
Dec 7 2019, 03:03 PM
76-914
Dec 7 2019, 04:03 PM
Looks like it will be ready for next spring. Great job!
dlee6204
Dec 7 2019, 06:00 PM
After having this kit on the shelf for a long time I finally found the time to recover my seats.
DRPHIL914
Dec 7 2019, 07:24 PM
QUOTE(dlee6204 @ Dec 7 2019, 07:00 PM)
Click to view attachmentLooking good! Those really pop!
Gatornapper
Dec 7 2019, 07:30 PM
Yup. One of my fav 914's now.....
GN
QUOTE(AZBanks @ Dec 6 2019, 10:49 PM)
Saigon71
Jett,
Gatornapper
Dec 7 2019, 07:32 PM
Wish I could vote Phil!!! And LOVE those lights!
Kudos to Spoke!
GN
QUOTE(DRPHIL914 @ Dec 7 2019, 10:40 AM)
Gatornapper
Dec 7 2019, 07:41 PM
Engine quit running on Nov. 10th after running like new on Nov. 3rd with new .060 idle jets and getting carbs dialed in...have spent hours searching for cause because ignition is all new. Today discovered bad dizzy stuck in 27 deg. advance - no wonder she wouldn't start. One spring missing......
Weighing my decision on new dizzy & Pertronix ignitor, dumping points....
GN
FlacaProductions
Dec 7 2019, 09:09 PM
Mounted a washer pump, put a heater fan splitter and new hoses on, removed the backpad and re-glued some of the leather around the edges, prepped new seatbelts for install tomorrow, installed new outer window scrapers and plotted an approach for more tomorrow!
Jett
Dec 7 2019, 09:44 PM
QUOTE(FlacaProductions @ Dec 7 2019, 07:09 PM)
Click to view attachmentGreat looking car!
rjames
Dec 8 2019, 12:33 AM
QUOTE(Gatornapper @ Dec 7 2019, 05:41 PM)
GN
Get the 123 Ignition.
ClayPerrine
Dec 8 2019, 02:04 PM
Betty and I took Igor and Frody to Maverick Region PCA for cars and coffee yesterday morning, then on to the toy run in Plano, Texas. We took both cars home, I put the new Mahle Gas burners on Elwood, and we went to the Maverick region holiday party. We had 9 914s, including Igor and Elwood, in a display at the Grapevine Porsche dealer.
I was outside talking to a guy looking at the display, and when I walked back inside, I found out Igor won best in show at cars and coffee.
North Coast Jim
Dec 8 2019, 02:32 PM
QUOTE(ClayPerrine @ Dec 8 2019, 03:04 PM)
Congrats
Gatornapper
Dec 8 2019, 04:40 PM
Robert -
My first choice for sure - but currently out of my budget.
Know of a better price than $450? Of course I'll take contributions......
GN
QUOTE(rjames @ Dec 8 2019, 01:33 AM)
GN
DRPHIL914
Dec 8 2019, 08:14 PM
Today I did a few small things, I rotated the tires rear to front and the front to rear. Looking at tire wear it’s obvious the fronts had more wear inside than outside, rears were same, so it looks like I have more camber I’m front and none in rear.- will discuss that more on my suspension thread, but also I removed the front spacers and I put in the new 914rubber front control arm bushings then took it for a test drive.
Then I mounted my CHT gauge I got from Dakota Digital, worked on the wiring , almost ready to hook it up.
The I installed my heater blower I got a few months ago from kevin(Rhodguy), thanks Kevin! It works as advertised!
Sorted thru some parts. I will be listing a few soon in classifieds,
Then put in some new shiny parts i got from Bruce Stone, the cup washers and retainer bolts that hold the upper front struts in place wow what a difference!
-our with some old and in with some new.
- new fan in place- was 42 the other morning I was glad I had heater hose hooked up and seat heaters!
AZBanks
Dec 8 2019, 10:57 PM
QUOTE(dlee6204 @ Dec 7 2019, 05:00 PM)
Click to view attachmentHe's gone... PLAID!!!!!
AZBanks
Dec 8 2019, 10:59 PM
QUOTE(Jett @ Dec 7 2019, 08:56 AM)
I have been trying to figure out what to do with the fog light openings. Send me a pm with the details on the foglight grills.
euro911
Dec 9 2019, 02:11 AM
I swept out my RV garage in AZ today ... then looked around for a bunch of parts to bring back to CA - some for 'HOWARD' (our '71 914), and some parts for other World members.
Click to view attachmentClick to view attachmentClick to view attachmentLooks like I need to find a solution to a rodent issue I came across too
... As I was sweeping up, I heard some gnawing sounds that appeared to be coming from a transaxle crate, so I wheeled it outside and will open it up tomorrow (Monday) to see what's going on in there. Hard to believe a rat could have squeezed through any of the very small crevices the crate's door or lid has
Need to suit up and put on a mask to get rid of this mess as well
Click to view attachmentSide note ... I should have hired a contractor to apply a nice floor coating before I moved all the parts from my shop into this garage
... I plan to move everything out of the 2-car garage into the RV garage and have that floor coated first ... then I'll have to figure out how/when to get the RV garage done.
dcecc1968
Dec 9 2019, 06:52 AM
Change the transmission oil and replaced my leaking speedo drive gear bushing with one of 914Rubber's new improved bushings. Three things I learned
One, oil leaking from that bushing can spray all over the place to the point that it appears your trunk is leaking oil
Two, Had a bugger of a time figuring out how the threads/nuts worked and the order in which to loosen things to take off the bushing, until I got it out, then it all made sense.
Three, and most importantly.... NO MORE LEAKS!
mmichalik
Dec 9 2019, 04:33 PM
My daughter is going to get the black on black '74 when she turns 16 in April and, her new plates arrived today. Her middle name is Moon.
michael7810
Dec 9 2019, 05:32 PM
Drove it to a funeral in north Phoenix and was greeted with this on the drive home. Once again I’m glad I have heat and defrost
euro911
Dec 9 2019, 08:38 PM
WOW
... we got a little bit of hail up in Payson, but nothing like that
KSCarrera
Dec 10 2019, 05:46 AM
Started the bumper swap to lightweight Euro-style mouldings. Hard for we Europeans to believe all this cr@p lurks behind the US-spec rubber bumpers!
Jett
Dec 10 2019, 05:46 PM
Putting the last few bits of interior back in our 75 2.0... Targa pad, new lighter unit, and windshield pillar trim... fitting the stereo tonight and last few pieces of NOS carpet.
still looking for speaker to housing mounting brackets and flathead screws...
ndfrigi
Dec 10 2019, 06:41 PM
QUOTE(KSCarrera @ Dec 10 2019, 03:46 AM)
Click to view attachment Click to view attachment Click to view attachmentClick to view attachment
KSCarrera
Dec 11 2019, 02:47 AM
I couldn't believe the weights of the US bumpers when I read it on here - along with a warning to get help when removing the rear bumper... I did it by myself and just managed to duck out of the way when it crashed to the floor! :-D
Tbrown4x4
Dec 11 2019, 03:54 AM
My wife says you can't trust bathroom scales.
nein14
Dec 12 2019, 03:38 PM
Just picked my 15 year old Rallye ST seats for the upholstery shop originally bought these from Stefan was one of his first customers
nein14
Dec 12 2019, 03:39 PM
soccerplyr
Dec 12 2019, 08:20 PM
I put in a new throttle position sensor. Easier then I thought it would be. Don't know if Gary Cotton is on the world, but thanks for the detailed how to on youtube.
sb914
Dec 15 2019, 07:26 AM
KSCarrera
Dec 15 2019, 07:37 AM
Click to view attachment Click to view attachment Bye bye impact bumpers, hello glassfibre earlies...
mmichalik
Dec 16 2019, 12:45 AM
Put in my spokeworksled.com led brake lights and side markers on the 74. What a huge difference they make. Can't wait to get the reverse and turn signals put in. They are great!
Also put in the 914rubber.com led head lights. Amazing, they are literally night and day different. All bright and shiny here now!
mb911
Dec 16 2019, 05:32 AM
Put the gt style hold downs on..
KSCarrera
Dec 16 2019, 07:11 AM
Soon into (localised) paint - no more fat-chick bumpers, no more ugly side-markers...
North Coast Jim
Dec 22 2019, 03:33 PM
Finished up the install on the Tangerine Racing remote oil cooler. Redid the hoses supplied with true SS reinforced versions. While the engine was out did a valve check and replaced the cover gaskets. Installed a billet replacement for the taco plate. Rebuilt the oil breather system as it leaked like a sieve. Glad I did that as the internals were broken. No more oil vapor soaking the top of the motor I hope. Rechecked the Webers, they were new this past year, and found a few discrepancies. Made those right.
Assembled all and today turned the key for the first time since Octeenerfest. Started right up and runs great. Didn't exercise her too much as it's only 38 degrees out. All seems good so she's put away for the winter - in heated storage.
SKL1
Dec 23 2019, 12:22 AM
Took the red '73 to C&C at Penske Musuem in north Scottsdale yesterday. Took the silver '71 on a ride today- hadn't driven it in quite a while and it needed some exercise!
Wouldn't be doing that if I still lived in Iowa... (though actually it was 50 in Des Moines today but with lots of salt residue on the roads)
ClayPerrine
Dec 23 2019, 08:00 AM
Drove Igor around doing errands yesterday. Guy in a GMC SUV gave me a thumbs up at a light.
Driving an 914 never fails to make me grin......
Jett
Dec 27 2019, 11:25 AM
Installed most of the interior over the break.
AZBanks
Dec 27 2019, 02:35 PM
Put the new plate on.
Bucci
Dec 28 2019, 12:11 AM
Cleaned original outside rear trunk painted panel after paint touch up to rear trunk lid. Also washed inside original Viper color painted trunk.
euro911
Dec 28 2019, 12:36 AM
Nice looking color
mmichalik
Dec 29 2019, 03:13 PM
Went for a drive in the '74 and had to put it on a trailer to get it back. Looks like I lost the aftermarket fuel pump that someone had put in.
Fortunately, I have a spare CB Performance 3.5lbs rotary fuel pump here already. Gonna change it out on Wednesday.
