Full Version: what did you do to your 914 today
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336
euro911
Coincidentally, I'll be digging one of the 'P' cars out of storage and trailering it to AZ when we're finished with a bunch of CA projects ... looks like tentatively sometime in June idea.gif
Gatornapper
Pulled the carbs, intake manifolds and tins off the engine & started cleaning it up. Want to paint the tins before putting them on. Put in cooling vanes PO had removed - actually the flap over the cooler was in, but left to flap freely so that some air was flowing over the cooler, the air pressure was probably lifting it some so oil cooler was probably only getting a fraction of the air it should have. Have new T'stat ready to go in after cleaning engine.
RickS
Drove it to a field with a bunch of old beaters who drive way too fast. All have very sticky tires.
Three 6s, two GT style and my skinny. Click to view attachment Click to view attachment
Mueller
Spent way too much time removing the stuck and rusted screws holding on the headlight chrome ring. Tossing the headlights that came on the car.
Had to break out the Dremel® to cut the adjusters and the 3 per screws that held on the headlight ring. Someone used steel screws which rusted a bit.
ndfrigi
QUOTE(drem914 @ May 8 2020, 10:14 PM) *
QUOTE(ndfrigi @ May 8 2020, 09:48 PM) *
Thank you Franz!
Thunderchief
Sanded down the exhaust pipes today to even out the finish. Left is before and right is after.Click to view attachment
ValcoOscar
Thank you to Rich @914werke who came through again by sending me some sheetmetal so I can fabricate throttle body cover for my V8 car. A few more hours of trimming and painting left...here it is mocked up. Also added expanded sheet metal to fender vents...paint later.
Oscar
Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachment
Craigers17
Since all the cool kids are doing it, and I'm cleaning up the engine bay anyway, it seemed like it was time to freshen up the charcoal canister a bit. I'll add the new charcoal tomorrow and reinstall. Thanks for the tips Ian!
euro911
I yearn for the day I can get back to work on the car(s).
Gatornapper
Awesome job! Kudos!
Now whatever I do will be looking 2nd rate.........no way I can match what you've done!
Gunked everything and then pressure-washed (yes, all holes plugged or capped, made special covers to bolt over the intake manifold ports) with 2500psi, and STILL lots of places the black gunk, sometimes almost 3/16" thick, would NOT come off.
Almost hammer & chisel hard. 2nd attempt will be tomorrow, using Oven-cleaner.
I'm not going down to metal on my tins tho..........
GN
QUOTE(ndfrigi @ May 8 2020, 10:48 PM) *
eric9144
Went on a little drive yesterday with some San Diego 914 buddies, really fun time, think it was good for all of us to get out!
JFG
a nice city/country drive to work & back
JOEPROPER
Got 914-6 rear brake rotors, machined them down to size and installed them.Click to view attachment I don't know how to turn it...
flipb
Over the past week:
Got new 914 Rubber visors and installed them using the pins from the original visors, which I still have but are nearly disintegrated.
Installed heater hose from 914 Rubber
Capped a couple of interior screw holes with caps from... you guessed it, 914 Rubber
Tightened the thermostat cable to the engine flaps
Hoping to driving.gif this weekend!
SKL1
Continuing work on the '73... took the '71 on a nice ride before it got hot outside...Click to view attachment
ValcoOscar
QUOTE(SKL1 @ May 11 2020, 11:33 AM) *
Oscar
Mueller
Finished taking off the wrapping on the engine harness.That pile is what was taken off of the harness. The blue tape is used at factory splices using barrel splices (closed I believe)
914e
QUOTE(Mueller @ May 12 2020, 12:08 AM) *
What is that harness for? It looks modern.
914e
QUOTE(RickS @ May 8 2020, 08:26 PM) *
Those tires are so sticky they can drive upside down.
euro911
No 914 work again today, but I picked up a cheap Boxter that needed some TLC ...
Got the old Harbor Freight buffing wheel out and spent a few hours working on it ...
ValcoOscar
A little more massaging of intake cover I started this weekend.
Not a fan of excess wiring or exposed trunk cut outs that are typical with subaru or V8 engine conversions...
Oscar
Click to view attachmentClick to view attachment
eric9144
QUOTE(ValcoOscar @ May 12 2020, 08:30 PM) *
euro911
QUOTE(eric9144 @ May 12 2020, 08:32 PM) *
agree.gif ... It has to be the cleanest conversion I've ever seen drooley.gif
Cairo94507
@ValcoOscar - Wow- that is a very clean modification. smilie_pokal.gif beerchug.gif
76-914
ValcoOscar
QUOTE(76-914 @ May 13 2020, 07:47 AM) *
Oscar
sixnotfour
ClayPerrine
QUOTE(ValcoOscar @ May 12 2020, 10:30 PM) *
Oscar
Did you test to see if the top will still fit in there? From the pictures, it doesn't look like it will.
Clay
ValcoOscar
QUOTE(ClayPerrine @ May 13 2020, 11:16 AM) *
Oscar
Clay
______________________________
Yes Clay..I did, photos are deceiving. About 1/2 clearance.
Installing with four 6mm rivnuts. using flathead 6mm thumb screws for easy removal.
placing 2mm rubber strip on back of cover to eliminate scratches or rattles.
Hope to paint cover soon.
Oscar
ndfrigi
Oscar
Looks like this is the car you will be driving along with Jerry’s LS 914 for June 6. Can’t wait to see them both again.
Craigers17
Started and/or finished a few small projects...
Installed BD Stone's Heater J Tube block off plates...unfortunately I ordered the nice black powder coated ones, when I should have ordered the half painted, patina-laiden ones to match my tins.
Reinstalled the freshened up charcoal canister...
Started making an inexpensive GT-type front oil cooler shroud mold, that will ultimately be fiberglassed if all goes well...
Took apart the engine lid, and started sanding the grill parts....
Gatornapper
No pics, but soda-blasted 44 years of crud off of my engine, tranny and heat exchangers - yes, every tiny hole/opening to engine well-sealed.......beginning to look half-way nice.....heat exchangers looking almost new - if you don't look too close......
Cleaning & painting the tins will be next.......
OH! Just got incredible front floor mats from Stoddard with "914 - 50 Years" (in German) and they are stunning! Quality is superb. Really nice upgrade to the interior - highly recommend them.....here....
https://www.stoddard.com/91455100050.html
GN
nein14
New door panels Vs old ones to match reupholstered seats
nein14
nein14
cali914
very nice seat
Jett
QUOTE(cali914 @ May 14 2020, 09:10 PM) *
very nice seat
+1
cali914
Just arrived today. I think i am going to try and make the 2wd locking nut and backplate myself. I have so much time on my hands might as well go for it. Any extra tips that are not on the great instructions that are already on the forum would be helpful. Click to view attachment
76-914
QUOTE(cali914 @ May 14 2020, 09:32 PM) *
If your output flanges align with your wheel centers you can keep that dipstick by straightening it and drilling a ~3/4" hole in the trunk floor, Throw away the brace unless you intend to hook it to a sky hook. The tubing on the slave cylinder can be straightened and re-bent to suit your needs. Use the tube that carried the old clutch cable as conduit for your AN-3 hose. It will keep it from sagging and trapping air bubbles. Did you buy that Forester trans? Just finished converting mine to 2 wheel drive yesterday.
Mueller
Nice and clean. I'll wait 'till I test drive your car before I buy a similar transmission. smile.gif
Do you have a set of transfer punches to get that bolt pattern for the new plate?
ValcoOscar
I didn't care for the look of the plain LSV8 so I fabricated some brackets and valve covers. Simple bolt on, only three 6M nuts hold down brackets to existing studs. I also used 6m bolts to attach covers. Took me 4 hours and lots of curse words.
I will powder coat later.
Oscar
Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachmentClick to view attachmentClick to view attachment
raynekat
Nice Oscar
ndfrigi
wow nicely done again sir Oscar!
tygaboy
QUOTE(ValcoOscar @ May 16 2020, 03:12 PM) *
I didn't care for the look of the plain LSV8 so I fabricated some brackets and valve covers. Took me 4 hours and lots of curse words.
Oscar
Now if only you knew someone who could stamp some sort of a design into those for you... poke.gif happy11.gif
Seriously, PM me if I can help.
ValcoOscar
[quote name='tygaboy' date='May 16 2020, 04:07 PM' post='2815924']
[quote name='ValcoOscar' post='2815908' date='May 16 2020, 03:12 PM']
Oscar
[/quote]
I've made hydroforming tooling...just not for personal use.
I will PM you a bit later. I'd love to help in any way.
https://youtu.be/CRvySEKCH-k
Oscar
Steve
On the last 914 drive my ignition switch finally died and my daughter and her boy friend had to push start my car. So... replaced the ignition switch and while I was in there I replaced the upper steering column bearing, had Hollywood speedometer rebuild my tach with new glass, capacitors, etc. The Tach needle no longer bounces around like a cable operated 914 speedometer. I also finally wired up the turning indicator dash lights that stopped working after switching to spoke LED’s. Everything works now and looks much better.
Sorry about the glare in the photo.
mmichalik
Put the new 914Rubber seat adjuster handles on the '74. Makes such a difference having them there.
Also cleaned up and resprayed the wiper arms. They were looking pretty rough and 45 minutes later, they look brand new.
It's the little things, I guess.
cassmcentee
Rear Brake Cleanup
Invision Power Board © 2001-2024 Invision Power Services, Inc.
