KSCarrera
Aug 31 2021, 01:53 AM
Click to view attachment New numbers for hillclimb next weekend.
Gatornapper
Aug 31 2021, 08:35 PM
Got new Porterfield Racing brake pads for my front 320i calipers from Eric at PMB Performance - and WOW!
You woulda thunk I put in power brakes!
Another THANK YOU to Eric
GN
Shivers
Sep 3 2021, 01:45 PM
Click to view attachment Texture or no texture. With texture is easier.
Cairo94507
Sep 3 2021, 01:51 PM
I went to Cars 'n Coffee w/o my car as they are paving the streets in my neighborhood and I am not going to get that junk all over my car. So it needs to sit until I think the 10 or 11th. Bummer.
DRPHIL914
Sep 4 2021, 08:04 AM
getting close to having my motor ready to go back in the car, hoping by monday- lots of pics on instagram @drphils914
bludden
Sep 4 2021, 12:31 PM
I've spent 2 lovely (hot) days with John at Black Forest diagnosing engine issues. It was running really rich and it appears that after we went through several parts and adjustments, replacing the brain resolved it. Returning next week to diagnose and fix and oil leak (prolly push rod tube) and do a valve adjustment. I've done them before but not with having to remove heat exchanger stuff so I want to see John do it first. Also will diagnose the back up lights not working. I did replace my tach to solve a ground issue with it, after fiddling with sockets and bulbs for an hour now I have a high beam indicator and one turn signal light - thats a bit of a mystery, as it's a 74 but just has one light when I thought they still had left and right indicators. Still need to troubleshoot the horns, I can hear a quick beep when i hit the button so I suspect the ground wires are not right on the horns or something like that. Looking forward to getting out to TN in a few weeks!
Gatornapper
Sep 4 2021, 07:00 PM
BEAUTIFUL PHIL !!!
QUOTE(DRPHIL914 @ Sep 4 2021, 08:04 AM)
Gatornapper
Sep 4 2021, 07:08 PM
Met Rick B. at C&C this morning to park our 914s next to each other - as usual, only ones there, they get lots of attention.
Our C&C has been super this summer with maybe 300 cars of everything conceivable - a truly great and eclectic gathering - always lots of really interesting car folks.
Met a couple Porsche guys that live near me, one who is looking to get a great yellow 914 in Michigan who now drives a nice Meteor Grey 9971. 6-speed.
When I got home I pulled the gas tank to put in a new one. I spent $265 3 1/2 years ago to have original tank acid bathed, re-lined with lifetime guarantee by top local shop. Just before I put tank in I noticed new lining was peeling off - but wanted to get the car running so bad I proceeded anyway. Bad move.
For 3 years crud from the tank lining has been fouling my idle jets every other tank of gas - not solids, a gummy goo type stuff. Done with that.
GN
DRPHIL914
Sep 4 2021, 08:06 PM
QUOTE(Gatornapper @ Sep 4 2021, 09:08 PM)
GN
they make new OEM tanks, get a new one from AA.
Robarabian
Sep 4 2021, 08:23 PM
Painted it Silver!! Factory color.
Cairo94507
Sep 5 2021, 03:56 PM
Caught this little 914 on a C-2 Corvette forum posting. Nice, representing our cars in New Mexico I believe:
cali914
Sep 6 2021, 11:37 PM
Drove it to Easy for the first Saturday of the month event.
Arno914
Sep 7 2021, 01:05 AM
Had the same problem. Check the fuse in the fuse box, it may be slightly corroded. Little wiggling solved the problem and made the dual horns sound loud and clear (Far better than the cheapy Mickey Mouse horns in todays cars, btw.).
mikey63
Sep 7 2021, 10:23 AM
Hanging out with family at the Santa Rosa annual car show. My brother's Camaro and my Dad's Mustang.
Beach914
Sep 7 2021, 10:40 AM
My brother took delivery of my new toy over the weekend up in Monterey. It’ll stay up there for awhile hopefully getting some work done on it. Ill see it in late October.
KSCarrera
Sep 7 2021, 10:41 AM
Drove up a hill a few times (well, on Sunday)... Weber IDFs don't like rapid left/right/left/right turns, despite raised vents and reduced float height. ITBs for next season...
https://youtu.be/iQKMellM8qk
Justinp71
Sep 7 2021, 11:35 AM
QUOTE(mikey63 @ Sep 7 2021, 09:23 AM)
Man I would like to have a camaro like that sitting next to my 914...
, one of my favorite muscle cars. 914 looks good too!
Shivers
Sep 7 2021, 12:32 PM
QUOTE(KSCarrera @ Sep 7 2021, 09:41 AM)
https://youtu.be/iQKMellM8qkIf the float height is too low, the fuel can move away from the jets and cause a hesitation. I put in the CB kits to get rid of the weber burble (technical term) in the tight turns.
@KSCarrera
SKL1
Sep 7 2021, 01:12 PM
Nice split window too Cairo...
930cabman
Sep 7 2021, 05:25 PM
Getting ready to pull the engine/trans. A new to me '75 example has several issues including a bad oil leak.
Gatornapper
Sep 7 2021, 06:46 PM
While waiting for my new SS fuel lines to arrive before I put in the new fuel tank, I sprayed down the tank bay with a strong cleaner and then pressure-washed it.
Clearly the first time it's ever been cleaned.
Much more better and now ready for the new lines and tank.
GN
LefthandRev
Sep 7 2021, 06:56 PM
In the month since acquiring this car, I've fixed numerous things.
- Fixed the fuel flow issue to the Webers
- Ran a hose between the cylinder head ports to stop oil leakage
- Added shoulder belts instead of lap belts
- Installed an alarm system
- Installed a new bluetooth radio
- fixed the driving/fog lights
- Added headlamp relays and fixed high/low beams
- painted the rear grill
- cleaned up some rust accumulation, primed, then coated it
- Added the shifter bushing at the firewall (YAY SHIFTING)
- Fixed the targa latch squeak above my head. Maddening!
- Changed the oil (simple, but didn't know how old it was)
- Ordered rear sway bar down-arm (one was missing).
- Added a fire extinguisher
- Added the Ford solenoid hack to the starter.
Jett
Sep 7 2021, 08:28 PM
Took the 75 Palma car in to have the first gear synchro addressed and turns out that 2end and 3rd gears are gone as well and the inner case looks like at some point it had ran the oil for too long. Ordered all the parts for a complete rebuild after the case spends time in a sonic cleaner.
We expect that this is the last gremlin before we call the restoration complete.
djway
Sep 7 2021, 10:35 PM
QUOTE(cali914 @ Sep 6 2021, 10:37 PM)
Click to view attachmentAny more pictures of the ducting?
mmichalik
Sep 8 2021, 09:50 AM
I put in a new set of Stainless Steel fuel lines on Monday. Will be installing the new gas tank on Thursday and we'll start her up.
A total PIA but, gratifying at the same time.
Gatornapper
Sep 8 2021, 09:58 AM
What? We are on parallel paths? Only I'm a week behind you.......
QUOTE(mmichalik @ Sep 8 2021, 09:50 AM)
Jett
Sep 10 2021, 09:21 PM
Some pics from underneath
Jett
Sep 10 2021, 09:27 PM
Double post
Shivers
Sep 13 2021, 06:18 PM
Click to view attachmentReceived new to me struts...Great Googly Moogly, if you know what I mean.
Thanks Mark for everything.
Too hot here to work right now, Maybe in a couple days.
@mepstein
Gatornapper
Sep 13 2021, 06:55 PM
DITTO but a week behind you - received the lines from Pelican today, installed them (lot easier than I thought but still a PIA to get the lines through the front grommet).
Few small things to do but hope to crank her up tomorrow.
GN
Chaznaster
Sep 13 2021, 07:41 PM
Changed out the transmission fill plug - the allen head on it was pretty badly stripped - with a new one. It’s not much but any day working on this car is a good day.
One surprise was the 15-18 torque spec. The old one wes definitely in tighter than that! The new does not sit flush to the case. Will watch for leaks …
jcd914
Sep 14 2021, 01:46 AM
Click to view attachment Not really what I did to my 914 yesterday but what it took to get to this picture on Saturday at sunset at Laguna Seca raceway.
I've been working to get her running and ready to go on our annual trek to Laguna Seca for the sportscar races. We have a group and we get the same 4 campsites overlooking the Corkscrew each year.
So I thought I had all the major running/driving issues taken care of so, Sept 1 I zipped off to AAA and picked up my current tags and found my license plate and invited my wife for a drive. I had driven it a few times illegally around the block before the windshield went in. Of course it can't be that easy, as we prepared to back out of the driveway, suddenly I could not get it into reverse or first, yes the shift coupling bushing had disintegrated. Following the holiday weekend after grandkids/kids left, I 'MacGyvered' a pair of spacers/bushings for the shift coupling that I could slip in from the outside with the coupling installed, that took most of the slop out. I have new bushing ordered.
So now with a sloppy but functional shifter I again invited my wife for a ride, this time went better until the car died and did not want to restart. It was a frustrating few minutes but I managed to get us home.
Click to view attachmentI charged the battery and installed a starter button on the dash and took the 914 for some new tires and then errands prepping for the trip to Laguna Seca.
Click to view attachmentAdded the tow bar bracket and off we went.
Over the weekend my wife and I tooled around the track in the 914 a couple times and took a drive through Monterey and Seaside.
Overall a great maiden voyage.
Click to view attachmentJim
ClayPerrine
Sep 14 2021, 07:01 AM
I spent the evening last night tracking down a short. Whenever I would put the screws in my instrument cluster, the gauge fuse would blow. I have the 5 gauge dash in my big six. I have a volt meter in with the gas guage, and I found that the power lead for the volt meter was hitting the dash frame behind the gauge. The power lead is insulated so that wasn't the short. The connection on the back of the volt meter was broken loose, and when the wire would hit the dash frame, it would push the connector up and cause it to short on the gauge housing.
I rewired the gauge so the G connector on the back of it is now the power lead. It is up high and won't interfere with the dash frame.
And I started to hook the radio back up. The used Hirschmann power antenna I have doesn't have the leads to make it go up. That will have to wait, as I need to get the car up and running this week for Okteenerfest.
Clay
Gatornapper
Sep 14 2021, 08:14 AM
That is one sweet and beautiful 914 - thanks for the pics!
GN
QUOTE(jcd914 @ Sep 14 2021, 01:46 AM)
Jim
Arno914
Sep 14 2021, 09:01 AM
Watered the 914, maybe she grows becoming a -6
Had my taillights sealed to the body with 5mm epdm foam strips and no more water entering the trunk.
Chaznaster
Sep 15 2021, 07:35 PM
Fiddled with the choke on my Weber 32/36 after finally running power to it. It was adjusted open when I got the car. The choke does not seem to respond when I give it 12v. Also learning how to tune these - will sleep on it and try again tomorrow.
mikey63
Sep 16 2021, 02:36 PM
Drove it!!
bludden
Sep 16 2021, 03:05 PM
My original tach was not allowing the lights inside to work. Took it apart and found a cold solder joint broken where the ground attaches to the casing right where it was easy to get a soldering iron in there and redo it. I hate removing the front casing but it all went back together. Oh also the clear covers for the illumination bulbs got reglued as they were rattling around in there. If it's not raining tomorrow I will replace it as the temp tach I got pretty cheap has a rusted ring. Also have a replacement part for the broken seat adjustment handle to get in.
Chaznaster
Sep 16 2021, 06:48 PM
Got the choke working. Voltage to it was ~5. Cleaned the contacts for the relay board fuse and put in a new one. Got 12.7V. Problem solved!
mmichalik
Sep 18 2021, 05:25 PM
Dropped the new gas tank into the 74 and she fired right up. Stainless steel lines went in a week or so ago.
No leaks, no fuss and most importantly, no fires.
I got a new carpet kit for the car as well so, I won't put the interior all the way back together tomorrow.
But still. Kind of cool.
ndfrigi
Sep 18 2021, 05:49 PM
QUOTE(mmichalik @ Sep 18 2021, 04:25 PM)
nice! that is a happy 914 weekend!
DRPHIL914
Sep 18 2021, 05:56 PM
I started it and did the 20 minute break in run.
first time running since May when the dropped valve seat.
3.5 months! motor sounds great-
i posted a video on instagram- #drphils914
tygaboy
Sep 18 2021, 06:11 PM
QUOTE(mikey63 @ Sep 16 2021, 01:36 PM)
Drove it!!
@mikey63 - Looking awesome!
infraredcalvin
Sep 18 2021, 06:16 PM
Chaznaster
Sep 18 2021, 07:10 PM
I am trying to address the popping noise I get when decelerating in gear. Changed the fuel filter. Changed idle jets on the 32/36 - 50 on venturi 1 and 60 on venturi 2. Checked valves (all were nominal). Adjusted carb with new jets to lean fast idle. Double checked timing (also nominal). There was definitely an improvement.
The took a drive and fiddled with teh 123 dizzy. Made some improvements by stretching the advance across more of the RPM spectrum. It was significantly better.
930cabman
Sep 19 2021, 07:00 AM
QUOTE(Chaznaster @ Sep 13 2021, 07:41 PM)
Yes, they get rounded out from guys overtightening. A bit of teflon pipe dope and you are in business. As I recall they should sit proud of the case.
Chaznaster
Sep 19 2021, 07:47 PM
QUOTE(930cabman @ Sep 19 2021, 09:00 AM)
Thanks! I drove about 25 miles yesterday and no leaks!!
burton73
Sep 19 2021, 08:47 PM
Today my 75 car had a chance to meet up with its new owner. Monday it will get loaded on UHaul and make its way up to new home in Northern CA. Nice that this CA car stays in California. Note that the 914 looks to sit around 2 inches to 3 inches lower than my MB SL500
Bob B Burton
PaulFV8
Sep 19 2021, 09:18 PM
I spent yesterday taking the paint and bondo off the rest of the fenders and found another fine mess the POs left for me. I have a couple of local sources looking for a replacement corner.
914e
Sep 19 2021, 09:26 PM
QUOTE(PaulFV8 @ Sep 19 2021, 08:18 PM)
Click to view attachmentHow does that even happen? Was it a rust repair, accident repair, or both.
