mrbubblehead
Jan 7 2012, 11:45 AM
QUOTE(Harpo @ Jan 7 2012, 09:18 AM)
I received my new Koni sport although they probably will not get installed today. Should I have my struts repowdercoated to match my Konis?
i think they look good black. might not be as hard to clean as the yellow will. from the road grime and brake dust...
mrbubblehead
Jan 7 2012, 02:49 PM
the post man just dropped off my inner door seals from 914rubber.com
and of course another perfect fit. i cant wait to order my new door rubber and window felt.....
tradisrad
Jan 7 2012, 02:58 PM
replaced both seals on the speedo drive and changed the gear oil.
ClayPerrine
Jan 7 2012, 04:50 PM
QUOTE(Outbackskip @ Jan 6 2012, 01:21 PM)
Click to view attachmentClick to view attachmentMilled a hole in the top chrome targa-strip for my 36 LED 3rd brakelight and installed it on the 914, I think it worked out pretty well.
At least it makes it more visable now.
Later Skip
Now that is a COOL addition!
Where did you get the led assembly? I want to do this to my car.
flipb
Jan 7 2012, 05:01 PM
Drove it!!
On twisty roads!!
With the roof stowed!!
In 65 degree temps!!
In early January!!
Just got her back from getting new wheel bearings, replacing inner & outer driver's door handles, and radio wiring de-fuched-up so it works again. Driving great and now has the addition of Mikey914's wheel center caps on my Mahles...
I should get to drive it a few more times this week. Might try to clean it up a bit.
djm914-6
Jan 7 2012, 05:07 PM
Picked up my Mini from the bodyshop today. Took thr 914 out for a fill up and a new bottle of sta-bil for a short winters sleep... I hope.
sfrenck
Jan 7 2012, 05:29 PM
Dropped the engine and transmission to clean up the hellhole
Thanks to Brenz and Mepstein for helping a brother out.
914dave
Jan 7 2012, 05:38 PM
Mounted a new firewall shift linkage bushing. Laying out an aluminum dash to replace the vinyl dash face. Covering the radio hole to run a Secret Audio system in the car.
hot_shoe914
Jan 7 2012, 05:42 PM
Ignored the two that I can drive and thought about the one I can't.
AndyB
Jan 7 2012, 07:05 PM
Installed some loud a$$ air horns from Harbor Freight no more meeeeep
PDXMike
Jan 7 2012, 08:33 PM
Did a compression test. Low on #1, but I hadn't adjusted the valves, so there's still hope!
partwerks
Jan 7 2012, 09:17 PM
Had the mechanic figure out as to why the left rear wheel has been squeaking. Needs the caliper to be rebuilt and had him check out as to why the shifting has been sucking lately. Maybe something internal, as opposed to external.
brp986s
Jan 7 2012, 09:21 PM
Loaded case. Pretty much standard build...
Click to view attachment'cept for these 98s for added spice:
Rocky
Jan 7 2012, 09:54 PM
Just picked up some beautiful original style seats in black leather from Jerry in Kelso. Can't wait to put them in. Will now sell the Corbeau Classic II's in near new condition.
Im going for the original look. Only a few small things left...
ConeDodger
Jan 7 2012, 10:09 PM
All I could do was think of mine since she is down at Original Customs awaiting 'hip replacement surgery'...
ConeDodger
Jan 7 2012, 10:11 PM
I expect she is going to look something like this when we're done...
JRust
Jan 7 2012, 10:18 PM
More paint
bcheney
Jan 7 2012, 10:29 PM
Installed engine and tranny into my 6 conversion!!
aharder
Jan 7 2012, 10:44 PM
All I got to do was look @ her and think about what I needed to do next while I had a few cold ones
Ya wanna see?
Strudelwagon
Jan 7 2012, 10:58 PM
Today was vacuum hoses.....all new in prep for the first start in a year
etcmss
Jan 8 2012, 04:54 AM
shot primer to the front and rear trunks.
Zardozz
Jan 8 2012, 12:49 PM
Pulled out of a parking lot and snapped the last bolt on the drivers side CV, CLUNK BANG! The remaining 3 bolts were still in place just unthreaded themselves... ? Found the pins. 3min, an allen wrench and some gloves was all that was needed to limp home. Kinda scary...
76-914
Jan 8 2012, 06:44 PM
mrbubblehead
Jan 8 2012, 08:37 PM
tore down a 1.8 to rebuild as a back up engine...
matthepcat
Jan 8 2012, 08:44 PM
Fixed a front suspension clunk and had to make sure it was fixed in the Santa Cruz Mountains.
Also got my car back after the baby deer collision. So I used a steel bumper this time, and did the Nissan 350Z grille for the radiator. Also popped on some Hella lights for bling. The last thing to do is get my factory headlights back in.
EdwardBlume
Jan 8 2012, 10:04 PM
Looks good. Glad to see you won... not the deer.
EdwardBlume
Jan 8 2012, 10:09 PM
Here's what I (we) did today....
YouTube Video
EdwardBlume
Jan 8 2012, 10:12 PM
kontrabass47
Jan 8 2012, 10:49 PM
I removed old inner door seals, only to find my black plastic door sills are all warped and broken, gonna order new aluminum ones before I put the new seals in. Also blew number 11 fuse again, not sure what is up with my interior light, haven't been able to get it working, every time I try it blows the fuse.
slimeygecko
Jan 9 2012, 01:50 AM
Checked the tranny fluid level to find it was a quart short. After filling, I went for a drive in hopes that solved my shifting problems. It didn't. Now it's time to drop the engine and tranny for a rebuild on the trannsmission.
reharvey
Jan 9 2012, 01:33 PM
Got the engine installed in my black 73 project. Hooked up the fuel lines and the wiring today. Will do the exhaust and fuel pump this week. Ray
pete
Jan 9 2012, 03:08 PM
QUOTE(matthepcat @ Jan 8 2012, 09:44 PM)
Hey, nice car. What do you mean by the "did the 350Z grille for the radiator?" I can't see the grill in the pic.
Rand
Jan 9 2012, 03:21 PM
QUOTE(pete @ Jan 9 2012, 01:08 PM)
My favorite grill style for 914 H20 conversions. Tried to pull it out of his pic some, but too dark. Check out Jerry's example in the link below. One of my all time favorite teeners, now with LS1:
http://www.914world.com/bbs2/index.php?showtopic=73233 (see the third post for a clear shot)
matthepcat
Jan 9 2012, 03:34 PM
Yea, that is where I got inspiration to do this.
Mine still needs some work to make it match the curvature of the bumper (not that easy).
Work in progress all the time!
QUOTE(Rand @ Jan 9 2012, 01:21 PM)
JawjaPorsche
Jan 9 2012, 03:36 PM
Wow! That looks awesome! I hate you!
QUOTE(reharvey @ Jan 9 2012, 02:33 PM)
76-914
Jan 9 2012, 04:00 PM
QUOTE(slimeygecko @ Jan 8 2012, 11:50 PM)
You don't "have to" drop the engine
'73-914kid
Jan 9 2012, 09:57 PM
I installed the Tangerine Racing cable throttle linkage for dual carb setups. I'm very pleased with how it works
aharder
Jan 9 2012, 10:17 PM
I bought Rings today, and I received my step down exhaust studs today
So tomorrow, I'm off the the Head Shop to give them my new studs for installation
mrbubblehead
Jan 9 2012, 10:41 PM
QUOTE('73-914kid @ Jan 9 2012, 07:57 PM)
Click to view attachmentnice, i have this setup also....set it and forget it......i havent touched my carbs in months. i think the last time was when i installed the cables and pulleys.
PeeGreen 914
Jan 10 2012, 12:43 AM
Getting closer to having a zero bind in the front suspension. So much fine tuning. Spent three hours filing a marking and filing tonight
6freak
Jan 10 2012, 01:31 PM
new tail lite buckit seals! from Mikey914 hope that solves the leaking issue...gonna yank the motor real soon ..like maybe this weekend ...
MartyYeoman
Jan 10 2012, 02:04 PM
Drove to work.
EdwardBlume
Jan 10 2012, 02:21 PM
Nice!
6freak
Jan 10 2012, 04:02 PM
QUOTE(Marty Yeoman @ Jan 10 2012, 12:04 PM)
Drove to work.
to much salt
but fairly nice weather .....maybe sunday drive to track down some motor parts...and get in one last spin in the 2.0
Michael N
Jan 11 2012, 10:16 PM
I opened the box of five rims that just came home from a visit at Al Reeds. I will wait for spring to get tires mounted and then install them on my car. I have wanted classic 15" Fuchs on my car for some time now.
aharder
Jan 11 2012, 10:44 PM
I got one piston off the rod so it's cleaned and has a new set of rings it. The wrist pins gave me a fit
Tomorrow may be a couple more
mrholland2
Jan 11 2012, 10:52 PM
I went outside to drive it, discovered the battery was totally flat. The 3 month old battery is bad. . so, now I need to replace it.
poorsche914
Jan 11 2012, 11:01 PM
Sent off two driver side stainless heat exchangers to make one good one. Cutting the 2.0 muffler mount end off of the one with crack in pipe and welding that to a solid 1.7 unit. Will be delivered in the morning. Can't wait to install as it will do two things - get rid of the exhuast leak and allow me to hook up the heat
JFJ914
Jan 12 2012, 10:26 AM
QUOTE(aharder @ Jan 11 2012, 11:44 PM)
Use a propane torch and warm the piston, pins will then slide out w/ no drama.
Chris Pincetich
Jan 12 2012, 03:30 PM
I parked my 914 up the hill on the grass and covered it with three covers+tarps.
winter hibernation for now
