Harpo
Aug 14 2012, 03:28 PM
I installed a reconditioned dash pad and new pad & vinyl from 914rubber
David
rnellums
Aug 14 2012, 03:47 PM
QUOTE(euro911 @ Aug 14 2012, 12:12 PM)
Ross, is that original paint?
Looking at the house pix, reminded me of some lyrics in a song by the Kinks: Demolition ... "Then we'll build a row of identical boxes and sell them off at treble the profits"
Funny how the angle makes your garage appear wider than your neighbors' garages.
It is definitely original color. The paint is in such good condition that I think it must have been repainted. However, the hood, trunk and door jamb areas have definitely not been painted.
I'm in a neighborhood of duplexes, perfect for college housing. each house has a two car garage, and at least in my house, each of the three bedroom has its own bathroom. I feel like I am living in the lap of luxury! This is what the inside of my garage looks like after cleaning it saturday...
914_teener
Aug 14 2012, 07:13 PM
Fixing the interior stuff that has been bugging for a while....upper steering wheel bushing....and "while I'm there stuff on the dash.
OH....and a real fun one...almost done...fixing the odometer.
cary
Aug 14 2012, 09:48 PM
Saturday and Sunday. Took it to Packwood and ran the piss out of it.
26 runs on Saturday ( EVO Phase 1 ). Then 14 runs on Sunday. Oregon Region PCA AX.
So I figured I had 35-40 minutes at full throttle. Two spots on Sunday I ran at the rev limiter in second gear.
Real happy with the rebuilt engine and the MPS adjustments. Ran a little rich at the end on Sunday. But it was running pretty hot.
euro911
Aug 15 2012, 03:14 AM
Jeremy and I hoisted the rails for the D7 lift into a trailer and transported them from the house (where they've been sitting for almost THREE YEARS
) to the shop, in prep for the lift assembly party on the 25th.
Tony (arg) stopped by and helped us unload them. Thanks, Tony
I had to back the 'BB' out of the shop to move the rails in, so I took it for a quick spin around the block
Also ordered 32mm venturis and main jets from CB Performance ...
KaptKaos
Aug 15 2012, 07:55 AM
QUOTE(euro911 @ Aug 15 2012, 02:14 AM)
Jeremy and I hoisted the rails for the D7 lift into a trailer and transported them from the house (where they've been sitting for almost TWO YEARS
Give me a call. I left you a message about shop and those 145 jets. Not sure you got it.
Regardless, I had to re-order the Jets yesterday. I hope you didn't order same. I Ordered from Aircooled. The guy I ordered from before I left on vacation didn't have stock, and took it as a back order. Ugh... I didn't find out until I called him Tuesday morning to confirm delivery. I should have ordered from Aircooled to begin with and I should have the new jets by next week.
Shop class started again last night, fyi.
Talk to you later.
.PS I have driven my 914 to work since I've been back. Had to put the battery on the charger last night.
JawjaPorsche
Aug 15 2012, 04:00 PM
The silver chrome band around my heater/air controls really looked bad. I thought it was corroded beyond repair but I took some rubbing compound and after about ten minutes of hard rubbing, it looks like new. I am pumped!
euro911
Aug 15 2012, 06:08 PM
Rubbing compound works really good on plastic light lenses too
audio_file
Aug 15 2012, 08:52 PM
Thanks to Greenie, who told me that I really ought to block off those holes left in the tin where the hot air plumbing used to be... Put some miles on it in 80ish degree weather today and noticed much cooler overall engine temps!
Pic of completed mini-project:
mittelmotor
Aug 15 2012, 11:30 PM
Put on the manifolds, plug wires and started on the coolant plumbing. I also popped off the valve covers and gave the rockers a good shot of oil, and spun the engine over for the first time with the starter. Wheee!
ThinAir
Aug 16 2012, 12:37 AM
Worked on idle issues tonight. I expect it will still run rough in the morning when it's cold, but before tonight I hadn't been able to start it for a couple of days so this is progress. Tonight's test run showed that idle was pretty smooth once it warmed up.
smj
Aug 16 2012, 01:45 AM
Swapped the inoperative original tachometer (mfg date 3/70) for a hopefully working unit that's much cleaner (5/72). Didn't test because of recent noise complaints from neighbor...
seanery
Aug 16 2012, 12:09 PM
QUOTE(smj @ Aug 16 2012, 03:45 AM)
Didn't test because of recent complaints from neighbor...
Your neighbor has a thing against functioning tachs?
smj
Aug 16 2012, 01:01 PM
QUOTE(seanery @ Aug 16 2012, 10:09 AM)
Ha! Well I suppose I could've tried to simulate a signal without running the engine, but I didn't think I could whistle at the right frequency...
No, one night when I was putting the -6 in the garage around 11PM he came out to complain that I'd woken up his kids (whom I've never seen or heard, but anyway...). Houses are pretty close together here and apparently he decided that the living room, right next to my garage/living room, would be the perfect place to put their bunk beds.
To be fair, neither the -6 or the -4 are Prius-quiet, and my driveway is at an angle from the street so lining up and getting in can take some moving and revving. If I just back straight in and cut the motor, like I did Tuesday night, I have to push the car down and back up the driveway three or four times to get it straight while avoiding the knee-high concrete retaining walls on either side...
I'd say something like, "Small price to pay for the weather and the cars," but I just noticed my tax assessment...
Strudelwagon
Aug 16 2012, 02:35 PM
Finally, after 3 years of fixing I got to drive the beast. What a GAS!
I had one finally problem, the import document showed the wrong VIN (see build thread fo why) and the insuracne company ICBC wouldn't accept it. I had to drive down to the border and have the document corrected.....done and I now have plates.
euro911
Aug 17 2012, 11:26 AM
Finally got the last (4th) window installed in the trailer
Click to view attachment... and here's Jeremy performing subsequent clean-up
Click to view attachmentFor now, you'll have to use your imagination to see a 914 in there
matthepcat
Aug 17 2012, 01:46 PM
rnellums
Aug 17 2012, 01:49 PM
QUOTE(matthepcat @ Aug 17 2012, 03:46 PM)
Opened a new warehouse at work. Lots of open space and slippery floors
That industrial setting really makes yOur car's color/interior pop. Looks amazing. What paint is that?!
matthepcat
Aug 17 2012, 01:52 PM
Porsche 993 Arena Red.
Thanks for the compliment.
QUOTE(rnellums @ Aug 17 2012, 12:49 PM)
Cairo94507
Aug 17 2012, 04:56 PM
Matthepcat - Beautiful car.
914_teener
Aug 17 2012, 05:20 PM
QUOTE(914_teener @ Aug 14 2012, 06:13 PM)
Finished It!
Now I can fix the upper steering wheel bearing and............. and
I recommend doing this when you have nothing else to do or want to.......biggest exercise in patience in quite a while.
Rob
matthepcat
Aug 17 2012, 06:48 PM
QUOTE(Cairo94507 @ Aug 17 2012, 03:56 PM)
Thanks.
Michael N
Aug 17 2012, 08:15 PM
QUOTE(Cairo94507 @ Aug 17 2012, 02:56 PM)
I second that!
laflaur
Aug 17 2012, 10:09 PM
Started cleaning the engine bay in advance of putting the engine back in. The car has been down for awhile,I have been chasing a rear caliper flex issue.
laflaur
Aug 17 2012, 10:12 PM
Andyrew
Aug 18 2012, 10:37 AM
Hot damn thats clean!
hot_shoe914
Aug 18 2012, 09:31 PM
Tracked down that the current fuel pump is not working and removed it. Also drained all of the 20yr old fuel out of the tank and then removed the tank. I hope to drop it off this week to have it boiled out and cleaned. Then I will reseal it and paint it. I also discovered car already hey stainless fuel lines installed.
There is 20 years of dust I need to clean out of here. Also plan to replace fuel lines and brake lines from the resevoir.
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachment
shuie
Aug 18 2012, 09:57 PM
Attached my new clutch release bearing to my 0 mile gearbox.... weak.
I did send out some sideshift conversion parts out to Brad. Sent some of my 356 parts out too!!
I also took delivery of a 60 gallon air compressor and scheduled an appointment with an electrician to wire it up for Monday. Hooray for AIR TOOLS!!!
SLITS
Aug 18 2012, 10:34 PM
Replaced speedo cable and changed the oil.
euro911
Aug 18 2012, 11:10 PM
Spent a lot of time reorganizing and cleaning up at the shop yesterday (in prep for the Carb Clinic/Lift Party next Saturday) ...
The heat and humidity beat me up
... so I took a long nap today.
Porsche930dude
Aug 19 2012, 06:02 PM
glassed my camaro spoiler back together and fitted it to the trunk lid. also made a patch pannel for my lower front fender and tacked it in
Harpo
Aug 19 2012, 06:08 PM
Toay I put in the dynamat sound deadener
matthepcat
Aug 19 2012, 06:43 PM
Harpo, You might consider removing the sound deadening in the little "valleys" on your floor boards. Water can get into that area under your dynomat and rust will begin. You will not loose any effectiveness of vibration dampening from doing this.
Matt
MrHyde
Aug 19 2012, 07:03 PM
Grinding paint off today.. Wife made some Bannana bread to give to the neighbours as a " I'm sorry I made so much noise in the driveway today"...
Eric_Shea
Aug 19 2012, 07:04 PM
JawjaPorsche
Aug 19 2012, 07:37 PM
Took my teener to it's first car show and surprised it won it's class!
BIGKAT_83
Aug 19 2012, 07:46 PM
Took the top off and went for a 200 mile drive. Had a great time dodging rain showers. If it was raining in the west we headed east.
Bob
KaptKaos
Aug 19 2012, 07:55 PM
Replaced the battery that was refusing to hold a charge.
Cleaned up the engine bay a little.
Put in new bolts and lock washers to hold down the rain hats on the carbs.
Sanded and bondo'd the targa top some more. Going for that smooth look.
Added pics to the 44idfs I am selling in the classified
biggy72
Aug 19 2012, 08:43 PM
I replaced the radiator in my Honda Accord and cleaned up the engine bay.........then I got my 914 out and went for a couple hour drive with the top off. Sort of strange working on the Honda and not the 914.
bulitt
Aug 20 2012, 06:58 AM
Eric- Whats that big decal on your dash say?
solex
Aug 20 2012, 07:26 AM
I tuned my car yesterday, dwell angle, idle speed and timing, car is running like a Swiss watch.
Call me crazy but I love points....
Eric_Shea
Aug 20 2012, 11:34 AM
It's an IROC decal but made for a 901. "Rev Limit 7300" "Press Clutch to the Floor for Up and Down Shift" (or something like that...)
turk22
Aug 20 2012, 06:17 PM
I fixed it!
I was having a starting problem, detailed in another thread. Turned out the connector on positive battery terminal was really corroded and the end of the copper wire was also corroded. I changed out the connector, and cut about an inch off the end of the copper wire (to the starter) and she fired right up!
So I spent about $150 to fix a $5 problem....and I'm happy
(I think that about sums up the addiction)
Turk
poorsche914
Aug 20 2012, 07:20 PM
Adjusted the valves this morning... #1 was good, #2 exhaust was slightly loose, and both #3 & #4 had very loose intake AND exhaust
Tightened up a few of the exhaust nuts and FINALLY no exhaust leaks
Tore one of the valve cover gaskets somehow during installation so have to swap that out tomorrow to get rid of a major oil leak.
Running good and hope she continues to do so as I head to Illinois on Wednesday (600+ miles each way)
dlee6204
My rear lid stopped closing. My latch was worn so I pulled it out, welded it up, and ground down a nice sharp edge. It now closes better than it ever did.
metalmorphosis
Aug 20 2012, 10:36 PM
Heres some painting in the rain pics, it started after the first coat and I wasn't stopping. All patch panels have already been painted but ground bare where welding took place so I had to repaint everything. I also must admit that this was 3 days ago but I just loaded the pics today so that counts right?
metalmorphosis
Aug 20 2012, 10:38 PM
engine compartment before and after
mrbubblehead
Aug 20 2012, 11:19 PM
looks good.
6freak
Aug 21 2012, 08:17 AM
parked my lawn tractor under it
euro911
Aug 21 2012, 11:41 PM
1.More cleaning up at the shop
2. Looked at the cars
3. Bought 5 gallons of AW-32 for the D7 lift
