Root_Werks
Sep 30 2022, 05:40 PM
Drove the 914 for the first time at night yesterday. Need to adjust the headlights! Happy, all lights worked, even the little fresh air fan light came on.
Wife and I noticed it'd been 2 1/2 weeks since the 914 was driven. All I've had time to do is drive it just enough to keep it off a battery tender. Really hoping that changes next Spring/Summer.
914 Ranch
Oct 1 2022, 03:29 AM
I changed the name of my build thread. This is the third time I've done it. Hopefully I won't have to do it before I get run the car.
When the car is sorted behind the installation of the Arduino board all the electronics she is going to an Autocross
AZBanks
Oct 2 2022, 02:15 AM
I rolled it into the garage at the new house. I have several things to get done in the next couple months. I have to get it prepped so it is ready for RSR 7 next September then I have to finish the engine rebuild on the 944 Cab so it is ready in time for RSR 7.
KSCarrera
Oct 2 2022, 10:52 AM
Sixth in class in local speed hillclimb. PB at the end of the day, so happy with the result.
eric9144
Oct 3 2022, 09:56 AM
Had snapped off one of the seat adjustment handles when cleaning the car up for Luft8 (hadn't been washed in many months)...Of course the new ones look different from the old ones so you have to do both, 1st one took me like 45 minutes, the 2nd took like 10
Still need to reseal my Lexan back window but didn't want to take that on right before Luft, with the cage stuff in there I'm not sure if monkeying that window out is going to be easy peasy or a hellish endeavor
Click to view attachment Click to view attachment Click to view attachment
VegasRacer
Oct 3 2022, 04:39 PM
Replaced pivot. #91475027110
brant
Oct 3 2022, 05:52 PM
Flushed the trans and nut/bolt check tonight
Figured it was time after RRC and a local drive of a few hundred miles
Craigers17
Oct 4 2022, 04:52 PM
Installed a new accelerator cable in preparation for the installation of new Tangerine Dual Carb linkage install....
Click to view attachment You can see how easy it is to wrap one with the clutch cable ( I didn't leave it like that).....as well as how rust and grime builds up in the tunnel....
Click to view attachmentLuckily for me...someone has previously "modified" the pedal board for easier removal....
Click to view attachmentSpeaking of rust.....while I had the seats and floormats removed, I couldn't resist peeling up some of the tar.....found some surface rust....but all in all...pretty damn solid.....removing all the tar.....project for another day(s).
Click to view attachmentClick to view attachment
914Sixer
Oct 4 2022, 08:45 PM
3 Coats of clear caliper paint on fronts and rears
lesorubcheek
Oct 5 2022, 10:40 AM
Did some more plating this morning. Had to get a larger container and mix some more electrolyte since these were too long. Three strikes of zinc....
Click to view attachment and the dichromate dip. This pic has some dark shadowing, but in light the iridescence is nice. Much better than the previous black paint.
Click to view attachmentDan
914e
Oct 5 2022, 03:04 PM
QUOTE(914Sixer @ Oct 4 2022, 07:45 PM)
@914Sixer Did you use gloss clear caliper paint? That is all I have been able to find.
914Sixer
Oct 5 2022, 03:11 PM
Yes clear gloss but it really is not that shiny. Had to order it, none of the parts houses had it in stock.
shredtherad
Oct 5 2022, 08:55 PM
QUOTE(brant @ Oct 3 2022, 05:52 PM)
This brings up some questions from a noob: what are some maintenance stuff done on the reg?
every few hundred miles? etc?
CT
URY914
Oct 6 2022, 05:43 PM
Here's something probably no one else has done. I hung the body on the wall.
brant
Oct 6 2022, 05:52 PM
QUOTE(shredtherad @ Oct 5 2022, 08:55 PM)
CT
Nothing to often
I try to do oil /valves once a year or 3k-5k
But I’m big on over maintenance Because of the race car
And that has paid off on road trips (knocking on head now)
burton73
Oct 7 2022, 05:50 PM
Spent several hours moving stuff around at my shop like a big puzzle (not me but my Trusty assistance as my rotator cuff is totally ripped up and I cannot do anything with it for a long time) to get the 1974 with the 2170 RAT built eng. closer to the front so Eric and get it when my 6 comes home. Note that the rotissery is now carefully moved closer to the front door without scratching anything
Best to everybody,
Bob B
Click to view attachment Click to view attachmentClick to view attachment
brant
Oct 7 2022, 07:40 PM
QUOTE(URY914 @ Oct 6 2022, 05:43 PM)
Click to view attachmentNice. !
Not the same
But metal
MIATA’s are &@$”.?!
930cabman
Oct 8 2022, 05:28 AM
Got the heater working
Jett
Oct 8 2022, 10:42 AM
Took the 73 2.0 out and the seatbelt buzzer started up for no apparent reason, but the drive was great!
Craigers17
Oct 8 2022, 03:28 PM
Worked on converting to Tangerine Cable Linkage....made a few mods, added phenolic spacers, but ultimately I'm gonna need to buy taller intake manifolds as I have clearance issues with the plugs.
eric9144
Oct 8 2022, 04:38 PM
Found a decent 'stuff' solution to keep the spare fuses, relays, DME relay etc that's not going to shuffle around in the car while driving, its meant to mount to the handle bars on a bike, works great when you have bars in your trunk
URY914
Oct 8 2022, 08:13 PM
I hung the others side.
cali914
Oct 8 2022, 10:37 PM
Cairo94507
Oct 9 2022, 07:25 AM
My brother and I took her to Greg & Sandi Taylor's for their 6th Annual Porsches on the Green. I did not count but I would say probably 40 Porsches arrived and all looked terrific. Lots of fun and plenty of food. Great hosts! Thank you Greg & Sandi.
Here are a few pictures my brother took. I was having so much fun talking and looking that I did not take any pictures.
Michael
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachment
Jett
Oct 9 2022, 08:37 AM
QUOTE(Cairo94507 @ Oct 9 2022, 06:25 AM)
Michael
Great pictures and amazing venue.
I have been wanting to do something similar in our backyard, and end with a drive-in movie… maybe next year
lesorubcheek
Oct 9 2022, 09:07 AM
QUOTE(cali914 @ Oct 8 2022, 11:37 PM)
Impressive! Very clean and well planned. Certainly a lot of work, but something to feel good about.
Dan
914 Ranch
Oct 9 2022, 03:05 PM
The Gurney Flap pivot lever and the hinge all got screwed down today.
bzettner
Oct 9 2022, 05:53 PM
Took her (and my wife) out for 100+ mile beautiful Texas “taco run”.
914-300Hemi
Oct 9 2022, 06:05 PM
Drove it to Luft 8 today.
Had a great time
brant
Oct 9 2022, 06:09 PM
Loaded the trailer, race car, and all…. For salt lake on wed/thurs
kkid
Oct 9 2022, 06:19 PM
Adjusted valves today.
They weren't way too off.
Sounds awesome afterward.
Click to view attachmentkkid
anderssj
Oct 9 2022, 06:37 PM
Beautiful afternoon, we did about 60 miles…
FRUNKenstein
Oct 10 2022, 11:24 AM
930cabman
Oct 10 2022, 12:15 PM
QUOTE(anderssj @ Oct 9 2022, 06:37 PM)
Click to view attachment+1 for Fido
SKL1
Oct 10 2022, 12:47 PM
Drove them both this AM... weather has finally broken in the valley of the sun!!
East coaster
Oct 10 2022, 07:14 PM
Machined my rear hubs and rotors for 5 lug
DRPHIL914
Oct 11 2022, 03:27 PM
leaking rear caliper so time for swapping this out and new soft lines i’ve had since Eric offered the group buy on them, got a Motiv power bleeder, hope that helps, i did this yesterday and then standard pump and bleed method and still had a slight soft feel so will go thru the whole system tonight not just the one side, but new pads lines an calipers cleans it up hard to believe i did those lines and calipers 8 years ago!
76-914
Oct 11 2022, 04:04 PM
QUOTE(cali914 @ Oct 8 2022, 09:37 PM)
Very nice work Harry!
porschetub
Oct 11 2022, 10:42 PM
Been working on the rear of the car namely sorting tailight leak and fixing the resulting light surface rust as the OP's painters touch up was less that suitable in the trunk,now topcoated after using high zinc primer and POR15 for the worst area's which luckily were little.
Constantly looking @ my rusty muffler that is a bit of a dented mess underneath as came from a 911 but very sound otherwise,when fitted before first start after the engine conversion I give it a rough coat of zinc weld thru primer,rather surprised how long most of it lasted.
Selected Rust-oleum 2000F rated high temp exhaust paint for new coating but need to get all the surface rust off and that's not a quick job
speed metal army
Oct 11 2022, 11:02 PM
Click to view attachment Went for a 2 hour rip! Had to try out the new speedo.
It works perfectly up to 160kmh as far as I could tell
Allegedly of course
tygaboy
Oct 12 2022, 08:21 AM
@Cali914 - Harry, that looks GREAT! Can't wait to see this in person. Any idea when it'll be on the road?
914 Ranch
Oct 12 2022, 02:15 PM
The Arduino board is here, I watched Josh assemble the hole thing and test the circuits except for the flap. The motors sound bitchen. Lots of work in front of me but it's all installation and will be very gratifying.
Click to view attachmentThe motors roar. I got an air flow meter, 2 biometric pressure sensors with temperature and humidity. The Arduino board also controls the Gurney Flap It puts the flap in full up during breaking.
914 Ranch
Oct 15 2022, 01:34 PM
Going Digital. If I get everything working it will be posted here first. I think that this thread is responsible for over half of the over 42,000 viewers on my build thread. I almost feel like I am bogarting this thread...
Click to view attachmentI'm moving stuff back to the car, the wing is in place although I know it has to come back out for cleaning and centering of the servo.
VegasRacer
Oct 15 2022, 03:42 PM
Took my neices 7 year old son Leighton for his first ride in Elvira. He said it was "The Best Ride Ever."
914 Ranch
Oct 15 2022, 04:05 PM
Nice John.
Getting some more stuff done. Now I know where everything goes.
brant
Oct 16 2022, 12:10 PM
Raced it for three days in salt lake
930cabman
Oct 16 2022, 12:29 PM
Got #3 on the lift, building a new 2056 (with big valve heads, Elgin cam and twin Webers) for it and going after a bit of decay in the hell hole area. With 4 in the stable I have my work cut out.
Plan is one for each grandchild
speed metal army
Oct 16 2022, 07:35 PM
I finally rekeyed my door locks! Easier than I thought, and now both doors open with my key.
CCE
Oct 16 2022, 08:01 PM
QUOTE(speed metal army @ Oct 12 2022, 12:02 AM)
Allegedly of course
Did you had a mph speedo? Or was it a one to one replacement? Mine has a mph and I want to switch to km/h, In Mexico is what we use and mine was a California car…
East coaster
Oct 17 2022, 05:01 AM
