Tony at Translogcalled me to come up and check on the Engine rebuild for my '74 1.8L. It's in the reassembly stage with new Camshaft(for carbs), Rings, Heads, Cam/Rod/Main Bearings, Bushings Machine worked Crankshaft & magnaflux, polished mains, rods & Cylinders honed to original spec, R & R pin bushings Coatings and clearence measurements, seals......so, bottoms done, case is together, top end goes on this week, engine to be back in car and broke in before the end of the month for pickup to being her home.
Also all new Transmission Shift Linkage/bushings and Tony found that the tanny was missing the Pilot Bushing causing the clutch disc to rub on the bottom of the case!!!!! Ticking time bomb. So new Clutch Release Bushing and Disc.
Once I finacial recover from this I'll start on replacement Gas Lines and rear Springs.
Down the road I'll convert from single carb to Dual Carbs. It's a hobbie, not a daily driver so I can take my time getting it perfect.
Also, will think about getting the heating system working again, Everything appears to be there except for the air hose to the exhaust heat deflectors, and electrically the fans are not functioning. I'll really don't need heat, I garage the car in the winter.
