QUOTE(DRPHIL914 @ Apr 20 2023, 06:49 AM)
QUOTE(Cairo94507 @ Apr 20 2023, 09:05 AM)
@Bucci - Love your car.
STUNNING!!!!
@Bucci @Cairo94507 boy both cars are stunning!! man, michael, that car is really looking so awesome!!!! i know you get it out a lot, so that paint still look slike brand new that tells you what an awesome job they did on it!!! I will probably need to repaint and this time get it done better its just so easy to chip, that i know they didint get it to bond correctly, which is dissapointing since i speint about $8000 onthat portion of the job only 4 years ago.
-Bucci, i had that happen to me a couple years ago, bushing fell apart, i lost all but 2 gears, now i have the brass bushing in that coupler, not going to ever have to replace that again!!
@DRPHIL914 Thanks for the shout out and compliment on my car..! I’ve made and tried various bronze oillite bushings at the shifter console on the transmission. I prefer the forgiveness of the plastic bushings as I was causing a bind because the shifter rod seem to be too tight.
And for reference, almost 25 years ago I paid $6000 for my paint job. About $3000 more than I wanted to spend back then. One of the key components is letting the primer cure adequately and sanding. Sanding scratches can be minimal using the correct sand paper grades.!
