More work on the 'BB' today.
Finally bolted my 'temporary' EMPI oil breather to the firewall (it was Ty-Wrapped in for the RT-66 Run and flopping around, spilling oil everywhere)
... and re-routed the hoses.
Readjusted the front suspension height.
I found the problem with my oil temp gauge issue. The wire was disconnected from the spade terminal at the sensor, but was still crimped on to the jacket
... installed a new terminal
Click to view attachmentWith the battery all charged up, started it up and checked for oil leaks. NONE
914Rubber.com valve cover gaskets are 'BB' approved
... Thanks Mark
Around midnight, hopped on the Harbor Fwy and drove several miles south, then back to the shop to check it out. Still needs some carb fine tuning
Had another clogged idle jet, cylinder #3 this time. I really need to find out where this crud is coming from
The tank is clean, there's a new Carter pump & filter under the tank, new SS fuel lines, all new hoses (the expensive stuff) and there's another filter in the engine bay
Put the car back on the lift, swept the shop floor and came home. It's 4:30am - good night
