I had to run over to the shop to snag some specialized metric tools this morning so I could take more parts off of Dianne's 1.7L 'moder' (it's here at the house). Removed the cooling fan/pulley and housing, engine mount bar and bracket, alternator, and the remaining tin stuff.
When I removed the fan housing, one of the wave washers was missing, so apparently it's been [at least partially] apart at sometime in the past. Maybe the crank seals and/or oil cooler seals were replaced? ... maybe a total rebuild?
I won't know for sure how far someone's been into it until I get the heads off and take a peek inside
Later that same day, went to my auto shop class with a big box of tin parts. Unfortunately, the shop's parts washer pump failed last week and the new pump hadn't arrived yet, so I blasted the cooling fan/pulley, and some of the tin parts that weren't greasy.
The End
