Eric_Shea
Oct 7 2013, 11:22 AM
QUOTE(sixnotfour @ Oct 7 2013, 11:12 AM)
sixnotfour
Oct 7 2013, 12:21 PM
QUOTE(Eric_Shea @ Oct 7 2013, 10:22 AM)
http://www.914world.com/bbs2/index.php?sho...19750&st=60big lips
Millerwelds
Oct 7 2013, 01:13 PM
I spent all day trying to figure out why it was running rough and hunting at idle. Triple checked valve settings. New plugs, cap, rotor, wires. Used a laser temp thing to see that cyl's 3 and 4 were not firing. Pulled the plugs and verified spark. Pulled the fuel injectors and verified fuel although was not sure how much I should actually be getting. Ran through my mind 100 times why #3 and #4 would randomly stop working at the same time. Gave up hope and then came across a posting from Bruce Stone in 2007 stating that the grounds for FI 1&2 and 3&4 were tied together. Unplugged the grounds and plugged them back in and low and behold it ran perfectly. Reset the timing. Wondered aloud why i have been trying to fix this for three weeks and not driving the car. Thanked my lucky stars that it was an easy fix. Cleaned the grounds and put everything back together. Drove it to work in amazement at how something so small could make such a huge difference.
Thanks to Bruce for sharing some simple insight back in 2007 and thanks again for the pedal set I won at WCR in Lake Tahoe!
URY914
Oct 7 2013, 03:34 PM
Yesterday I won the B Mod class at the Florida State Autocross Championship at Sebring. My fourth time winning my class.
I had all kinds of stupid problems; starter, battery, carb, trailer winch, and the mount for the monster wing cracked at the weld. Plus second gear seems to have moved from where it used to be. I hoping the cone screws are loose.
bulitt
Oct 7 2013, 04:18 PM
QUOTE(URY914 @ Oct 7 2013, 05:34 PM)
They must tire of seeing you show up!
Oct 7 2013, 05:42 PM
Eric_Shea
Oct 8 2013, 09:07 AM
QUOTE(URY914 @ Oct 7 2013, 03:34 PM)
Congratulations Paul
Silver Surfer
Oct 8 2013, 04:48 PM
Finally got sick of the noisy Monza exhaust. Ordered new gaskets and nuts and dropped off the original muffler at Finishline Coating for ceramic thermal barrier coating in a raw steel finish.
KENNY
Oct 8 2013, 04:53 PM
QUOTE(URY914 @ Oct 7 2013, 01:34 PM)
Congratulations
Oct 8 2013, 06:00 PM
'73-914kid
Oct 8 2013, 09:03 PM
Had to run out and grab some chemistry supplies, so I took the top off and cruised around the Walnut/Diamond Bar area.. stopped for a bite to eat, and drove into the sunset back to school. Not a bad evening at all
boxsterfan
Oct 8 2013, 10:47 PM
Began the prep of a "new to me" 1974 2.0L for regular driving. Changed oil and filter. Verified the cooling flaps open when warmed up. Still trying to figure out of it is running hot or not.
Next up:
1. Take some pics
2. Install new sending unit and vdo gauge
3. Change tranny oil
4. Install new vacuum lines
5. Figure out the rough idle after engine warms up.
Hoping to get it sorted this weekend otherwise I might as well
Mike Bellis
Oct 8 2013, 10:58 PM
I opened the garage and looked at mine...
shoguneagle
Oct 9 2013, 01:01 AM
I got some critical parts taken in the theft; car is starting to become active again and not a "boat anchor". Got a DME and front bumper which will allow me to get it running and licensing in Oregon; more parts coming thanks to the 914world members. Will soon have enough to put it together and start upgrading for the objective of final painting.
JoeSharp
Oct 9 2013, 02:02 AM
Moved it back about 10' by hand. Well at least I touched it.
euro911
Oct 9 2013, 02:18 AM
I had auto shop class tonight, so I drove the old 'BB' again. Finally got access to a lift and found a loose cone screw at the shift console. Took the cup off, lubed it and reinstalled it, tightening the cone screw as tight as I dared to (didn't have any lock-tite handy, so I hope it holds)
Also checked the front cone screw ... I can report back that all was OK there. Added a little grease to the shaft there too.
While still on the lift, also adjusted the clutch pull and leveled the front suspension (was listing on the driver's side a tad, even without my fat ass in the seat).
Cleaned out cylinder # 2's idle jet AGAIN. Why is this one jet always clogging?
Put fresh air in all 4 tires before leaving and it ran a lot better on the way home. It sure is nice to have 1st. and reverse gears at my finger tips again
euro911
Oct 9 2013, 02:25 AM
QUOTE(Silver Surfer @ Oct 8 2013, 03:48 PM)
Click to view attachmentAre they dipping it (coating inside and out)? I'd like to do this to my
muffler too. How much are they charging you?
bulitt
Oct 9 2013, 08:52 AM
Well, I lost my nuts!
Seriously, no matter how organized I try to be, bagging and tagging, and boxing I still manage to lose nuts, bolts, brake stuff.
I learned today, a good place to find metal objects is on the speaker magnet.
Installing my brakes lines.
JawjaPorsche
Oct 9 2013, 03:39 PM
Went to town and fill the tank up with 100% gas before making the trip to Okteenerfest. Should make it back before needing more fuel. Awesome fall weather! Mid-70's, ZERO chance of rain! Okay, I have jinx us!
Mblizzard
Oct 9 2013, 04:50 PM
QUOTE(JawjaPorsche @ Oct 9 2013, 01:39 PM)
Will be doing that tonight and heading to Okteenerfest tomorrow. I hope to drive hard enough to need gas before I come back.
If it rains, you have to wipe down everyone's car now that you said it!
Mike Bellis
Oct 12 2013, 07:28 PM
Took it out for a little drive today...
Fun, Fun!
wndsnd
Oct 12 2013, 08:13 PM
Finally got my engine in!
All lights look good. Starter turns over. Tomorrow I am going to fire up that dANNY special
euro911
Oct 12 2013, 09:35 PM
The 'BB' has become my 'DD' since the shifting problem has been mitigated
KaptKaos
Oct 14 2013, 12:09 AM
Drove her all over today. Was a lot of fun too.
993inNC
Oct 14 2013, 05:08 PM
Put my dash back together last night. Working a little bit at a time
bulitt
Oct 14 2013, 05:17 PM
Looks great Chris!!!
Put new Aluminum fuel line in today!
JmuRiz
Oct 14 2013, 07:21 PM
QUOTE(993inNC @ Oct 14 2013, 03:08 PM)
Who did your leather/stitched dash? Looks good!
Btw today I tallied up the price of parts on my car...yikes.
Pat Garvey
Oct 14 2013, 07:38 PM
Finally bought 5 tires (Kumho's), mounted them on the chromies. Will be cleaning suspension pieces as I install. Should be back on the ground by Friday, for the first time in over 6 years!
Fuel tank and injection parts will need to be replaced but have everything to do so (all new, except for the replacement tank). Getting ready to order Tangerine lines and will have to farm out most everything since I'm getting older.
poorsche914
Oct 14 2013, 09:13 PM
Found this in a care package of 914 stuff given to me by a fellow PCA member who recently moved and was clearing out all his old Porsche junk.
infraredcalvin
Oct 14 2013, 10:12 PM
Well, yesterday, not today, got her up on the rotisserie I built! Waiting for tangerine braces then she'll be there for some prep.
euro911
Oct 15 2013, 11:34 PM
Blasted my banana
muffler at auto shop class this evening. Hoping to get some heat paint on it this week end and installed on the 'BB' shortly afterwards
993inNC
Oct 17 2013, 05:41 AM
QUOTE(JmuRiz @ Oct 14 2013, 09:21 PM)
Had a local guy do it. Took him a couple of attempts to get it that good. It's not perfect but better than the cracked up pad it used to be. Said he never wanted to see one again
I know he could have done even better, but this was small potatoes and he didn't charge me much so......
The bottom dash came out great and it's a nice touch to have the stitching modernize the look. There's a couple of extra pics in my resto thread
jrrhdmust
Oct 17 2013, 02:53 PM
Washed down the previously sanded down underside of the car, and painted with Eastwoods Rust Encapsulator. Next up Undercoating.
Silver Surfer
Oct 18 2013, 11:05 AM
Picked up the OEM muffler from Finishline Coatings this morning. Double ceramic coating. Very happy with the results. Excited to get it mounted tonight. Before/after pic:
mittelmotor
Oct 18 2013, 03:33 PM
QUOTE(Silver Surfer @ Oct 18 2013, 10:05 AM)
Click to view attachmentLooks great! I did the same thing with my LS1 exhaust manifolds, and was super-pleased with the results. Rusty cast iron is a real eyesore.
euro911
Oct 19 2013, 10:29 AM
Click to view attachment ...
What did they charge you to coat it? I had to drive up to Cedars Sinai Hospital in West LA yesterday. All the freeways were boogered up, so it was surface streets - up and back ... and a lot of shifting gears
Need to adjust the clutch cable a little more.
914itis
Oct 19 2013, 01:43 PM
Went back to stock front valence with a small modification.
JmuRiz
Oct 19 2013, 03:03 PM
Interesting, for a front cooler?
914itis
Oct 19 2013, 04:20 PM
I don't have that in my plans yet, unless I moved up with a bigger motor.
just looks kool for now.
euro911
Oct 19 2013, 06:08 PM
Click to view attachment Are those stock horn grilles, Paul?
914itis
Oct 19 2013, 07:47 PM
Mark,
Yes they are horn grills.
Matt Romanowski
Oct 19 2013, 07:51 PM
In getting ready for the track tomorrow, I replaced a wheel speed sensor, washed it, and put never wet on the seat. Tomorrow I'll drive it like I stole it.
Garland
Oct 20 2013, 10:47 AM
Rolled the project out, old to new, 914 barn in background.
dlee6204
Oct 20 2013, 04:42 PM
I finally got my car back on the road this afternoon. I had some fuel injection woes and think I finally solved it. Fingers Crossed.
TJB/914
Oct 20 2013, 04:55 PM
Went for a ride, filled the tank with Gas/Stabil, & filled the tires @ 45 lbs. pressure & pulled the cover on, patted the fender and said see you in the spring.
Tom
Oct 20 2013, 07:42 PM
TJB/914
Oct 20 2013, 07:48 PM
QUOTE(dlee6204 @ Oct 20 2013, 06:42 PM)
Better Photo.
Tom
See you in the spring 2014
euro911
Oct 20 2013, 07:58 PM
I was tasked with sanding some baseboards for the kitchen today
... however, I finished that chore in record time, and had enough 'spare time' to finish-sand a banana muffler that I blasted on Tuesday night
Click to view attachmentHope to get the baseboards
AND the banana painted tomorrow
Michael N
Oct 20 2013, 08:34 PM
I installed a third seat seat belt so that my kids and I can all go together on shot weekend trips around town. The giggles per mile were off the charts!
914itis
Oct 20 2013, 08:50 PM
QUOTE(Michael N @ Oct 20 2013, 10:34 PM)
Click to view attachmentHm!
Can you use an early buckle as a center?
