Ripped out the last of the old battery->fusebox wiring, wrapped the wiring in new hi-temp split loom, bolted in the 914ap speaker panels (nice parts!). Removed the ancient passenger harness and replaced it with a new Schroth number. Hope we never need them, but better safe than sorry.
Tried to find somewhere to mount my $20 eBay amplifier, but nope, too big, too heavy. Hopefully the PA275 that's in the mail will be light enough to hang off the old DIN rear pin.
Installed a Painless F5 fan controller... then realised that Rengegade used a 3/4 NPT fitting for the sensor on the radiator and making a 3/8 to 3/4 adapter using a 3/8 to 1/2 and 1/2 to 3/4 adapter results in something that will almost certainly not work. Bah.
Built a panel to mount the GM ECM and assorted other bits for the TBI conversion in the trunk.
Click to view attachmentTaught my homebrew LED instrument panel to read the data stream from the EBL Flash in the GM ECM; will let me do away with the speedo, tach, coolant temperature sensor wiring, read trouble codes, etc. Still a shocking ratsnest, but that's prototypes for you...
Click to view attachmentCleaned all the greasy fingerprints off the fenders and decided to call it a day. Everything lights up, so hopefully it'll start again.
