JoeSharp
Feb 5 2014, 04:32 PM
I bought some headlight buckets. Going to put them in the front bumper where the for lights go.
Jesco Reient
Feb 5 2014, 07:26 PM
I drove it, Drove it and enjoyed the heck out of driving it, Yesterday I drove it. The car was wonderful and it was beautiful outside and in the evening when I got it home a gentle snow was drifting around as I put it away. I would have posted Yesterday that the day day before I repacked the wheel bearings, changed the oil and adjusted the venting on the brakes, however I was busy driving it.
Wait........ I think I'll go drive it some more.
Then I'll look for something else it might need.
euro911
Feb 6 2014, 04:27 AM
Ran across some boxes of neat stuff I acquired a while back:
1 A set of A&P speaker pods with Blaupunkt 6" speakers I bought from Kevin (rhodyguy) ...
(maybe I'll install the new carpet kit while I've got the old pods out)
2. The LED dash gauges that Tim (timothy_nd28) upgraded (finally found the errant wiring harness), an early metal gauge plate
.... (that I'll repaint ) and substitute it for the funky plastic one, and install a set of SpunOne's gauge rings
3. An Engman fuse box
... and
4. A set of CAMP 914 rear trunk shox (so I can finally get rid of that old 2x4 the holds the lid open)
DRPHIL914
Feb 6 2014, 06:44 AM
no new pictures of the brake lines, but yesterday i pulled out the rear brake regulator because i could not get the old line off, bad angle to get the top one(driver's side) hard line off of it, took about an hour , but progress was made! new line attached regulator back in place- what a mess!!! undercoating everywhere on the regulator etc, even the bottom of the fan housing, So did they spray that on like that at the factory? must have been a dealer or aftermarket application to be all over everything like that!
- but replaced all the hard lines from both sides,
- put in new push rod tubes and seals on driver's side, both sides are now done!!
- installed new brake line clips,
- picked up my wheels- new tires mounted to my fuchs that are going the 5 lug conversion
- but- my lugs seem to be 1-2mm too long to really tighten down my rims good, so i guess i bought the wrong lug nuts-they are like caps, maybe not quite deep enough?
-kind of a bummer they are really nice alloy porsche lug cap/nuts! , so one setback , but hoping to mount the left side suspension and the set the valves this weekend, finish the left side mounting of the brake calipers, bleed rear brakes, set rear brake venting - then drive a bit , put her back up to do the front!!
DRPHIL914
Feb 6 2014, 06:47 AM
Test fit new tires/ wheels komho 195/65-14's
euro911
Feb 6 2014, 01:20 PM
Phil, how long are the studs you put in the hubs? ... maybe that's the issue
2mAn
Feb 6 2014, 02:07 PM
QUOTE(moe @ Feb 4 2014, 06:09 PM)
Zambezi?
DRPHIL914
Feb 6 2014, 03:00 PM
QUOTE(euro911 @ Feb 6 2014, 02:20 PM)
i'd have to check, they were put in by Eric, at PMB for the group buy last year, so they should be right for fuchs i would think. Eric has the same 14" fuchs, mine came off of a '70 914/6 owned by Luke M. I put in an inquiry to Eric but i have not heard back, i'm sure i will soon. its so close, but i was looking at the hubs and it does not look like you could put them in further, but i might be wrong. i would say maybe 3mm is all . i did find some 5mm spacers but i am kind of leary of using them. Back 30 years ago i had a '69 Healey sprite that had flares and oversized tires(set up for A/X) and the P.O. had put in some shims, when i went to do the brakes, after putting them back in they worked loose, i had not rechecked them and as they loosened the wheel locked up, bolts sheared off and the rear end dropped to the ground, on a highway on-ramp! and there went these nice shine discs rolling down the road past me, LOL! funny now, no major damage, but it sucked then. anyway i am sure it can be safe i just think it might be partly why they loosened up on me.
i will measure tonight when i get home and maybe i will hear from eric by then.
JawjaPorsche
Feb 6 2014, 03:26 PM
Drove my teener to my favorite BBQ place for lunch. It is only open three days a week: Thursday thru Saturday. When they run out of BBQ on Saturday, they close early! You gotta love the name!
DRPHIL914
Feb 7 2014, 08:34 AM
Mark,
took a quick look this morning, and with the rotor in place the lugs stick out
about 1&9/16, just over 1.5".
Eric said he could sent over different length ones, but that would be a pain and i'd have to wait for those to come. or if i have enough room i could safely use a small spacer, so just for now my quickest two options are either,
A; get lug nuts that are open ended, or
B; use my closed ones with a 5mm spacer. I had 195/55/15 on the EMPI that i just took off, so since my fender lips are rolled in, i should be o.k. to run the fuchs with my 195/65's(14) and a 5mm spacer. i just want to get the car on the ground this weekend so that i can pull the front wheels to get then shipped out next week. will the local flaps have the proper thread lug nuts?
pjw
campbellcj
Feb 7 2014, 11:34 AM
I finally applied my race numbers last night, as well as a factory racecar-style hood crest decal. I still have a bunch of other decals to put on but probably not till later.
Also I just picked up my new Braid 15x9 repro Fuchs with fresh Hoosiers. They seem like nice wheels and I will buy more if this pair works out well.
Will try to post pics this weekend from Willow Springs.
euro911
Feb 7 2014, 02:09 PM
QUOTE(Philip W. @ Feb 7 2014, 07:34 AM)
Mark,
pjw
Hey Phil,
Not sure what the cost or availability is for 5mm spacers, but Pelican sells a set of open lug nuts for $40. if you can't find a set of used ones locally
Click here
DRPHIL914
Feb 7 2014, 02:56 PM
QUOTE(euro911 @ Feb 7 2014, 03:09 PM)
Mark,
pjw
Hey Phil,
Click hereMark,
Thanks for the info. i found those on automotion, AA and pelican, same price everywhere. I like the acorn ones and they have tall acorn ones too, but i ordered these also because they are required for any D.E. or track stuff, and i will be taking out to Robeling Road for some PCA DE stuff soon as its finished!!
I could have ordered the spacers but they are $$ and thought even 5mm spacers might make it a bit tight in the fenders on my narrow body car, although i think with the lips rolled under i would have been o.k.
Most good spacers were like $25 or more each, so i opted for the open lug nuts.
i checked everywhere today, no one has the 14, 1.5 threading in stock. I ordered them from pelicat
ndfrigi
Feb 7 2014, 06:38 PM
Test fitting a Fuchs wheels with old 195x60x15 tires if it will have a nice fit on a narrow body. Thanks for my cousin who came down from Bay Area to visit my family and with this free wheels. Plan of polishing them and buy a set of new tires.
AfricanHijinx
Feb 7 2014, 07:19 PM
put in some new rubber from Mike
Click to view attachment this is the passenger side and the scraper doesnt seem to fit right at the end.
euro911
Feb 7 2014, 10:44 PM
There's a small plastic end cap that attaches to the end of the scraper (it screws into the door), so you'll need to trim the scraper when you go to install the end cap.
Which end cap you need depends on the year of your car:
Early - click hereClick to view attachmentor
Late - click hereClick to view attachment
euro911
Feb 8 2014, 12:01 AM
Bled the MC on the bug, then re-bled the wheel cylinders - all four corners are working great now
Click to view attachmentGot the bug motor all back together with all the correct tins, hoses, stock air filter, etc. and got rid of most of the chrome aftermarket crap the PO stuck on there
Before
Click to view attachmentAfter
Click to view attachmentAlso, installed a new sound system in the Westy Camper
r3dplanet
Feb 8 2014, 02:22 AM
I do so love the Beetle. Always nice to see one get the love it deserves.
carr914
Feb 9 2014, 02:30 PM
carr914
Feb 9 2014, 02:32 PM
bulitt
Feb 9 2014, 03:03 PM
QUOTE(carr914 @ Feb 9 2014, 03:32 PM)
Wow! What's that capacity like 100 gals? You can power up your generator during the next hurricane?
carr914
Feb 9 2014, 03:56 PM
20 Gallons
euro911
Feb 9 2014, 04:58 PM
A very rare fuel tank that could be obtained for 356s and early 911s were 100 liter tanks (approx 26 gallons). Again a VERY rare item and BIG $$$ to find an original one.
euro911
Drove the 'BB' up to Azusa yesterday for a dinner gathering at the Canyon City BBQ (80 mile RT). I need to get my ass in gear and re-jet the carbs - still not quite right
I'll be devoting most of my free time over the next few weeks getting the Bug back on the ground and preparing the Westy for it's maiden camping voyage to Cuddeback Dry Lake (same w/e as the RT-66 event)
In addition to an oil change and a minor tune-up, I need to install some solar panels and 'nerdy' communications antennas on the Westy.
ndfrigi
Feb 12 2014, 05:23 PM
Drove it with my wife and she took a picture of me (sorry for the tongue out, making a funny face on my wife) with 65 mph under an overpass along 405 freeway around long beach airport.
JStroud
Feb 12 2014, 06:22 PM
Had some more of my -6 conversion parts show up today.
My MSDS ceramic coated headers and exhaust showed up. Headers look awesome Marty, thanks again.
Flywheel and clutch are at the machine shop getting balanced, the car goes into McMarks shop on Sunday for the new motor mount......things are starting to move along. Be nice to
it to WCR.
Jeff
euro911
Feb 13 2014, 12:21 AM
Nice toys Jeff
More Vanagon work today :
Removed the curtains and rear upholstery, washed the fabric and sprayed the foam pads with Febeze
Fabricated some brackets for a roof rack ...
Click to view attachment... and got them installed right around sundown.
Click to view attachmentPlans for tomorrow : Install the cross rails and install two 100 watt solar panels on the rack
914 content: I still have a couple of them
JStroud
Feb 13 2014, 12:38 AM
QUOTE(euro911 @ Feb 12 2014, 10:21 PM)
Nice toys Jeff
Nice, I just installed three solar panel to heat the pool at my Mothers place in Nevada City, last year wired them in a 14k back up generator.
Last year I built a shop in Isleton, wired it for generator and solar, they got solar panels installed, 36x50 shop no utilities at all. Love solar.
914 content
Tried the new wheels on the new driver...fit great, now to clean them up, get some new tires mounted and get that thing back on he road.
Jeff
jrrhdmust
Feb 13 2014, 02:15 PM
I finished installing the brackets for the front sway bar on the left side. I welded the hole closed that I drilled in the wrong place, and I made two patches and welded those in. Finally I scrubbed everything under the gas tank.
Need to have a snow day more often!
euro911
Feb 13 2014, 11:31 PM
More Vanagon ...
Changed the design a little - so I had to remove the brackets and make a fixture to uniformly bend the upper ends of the brackets ...
Click to view attachmentCut a couple lengths of shallow aluminum UniStrut for the cross rails ...
Click to view attachmentand installed two 100-watt mono-crystalline panels (wired in parallel) ... approx 15 Amps of power in full sunlight
Click to view attachmentI need to fabricate a wind deflector for the leading edge of the panels next. Maybe a 914 'duck tail' trunk spoiler will do the trick
I'll be installing a 20 Amp charge controller, an Odyssey sealed battery and a 1500-watt power inverter under the rear seat.
914 content: 914s are cool
campbellcj
Feb 15 2014, 09:44 PM
I installed my new rear Braid 15x9 Fuchs repros with fresh Hoosiers. I was going to sell them but may be keeping the 16x9 Fuchs too, for the taller gearing effect. But the next event is short track (Streets of Willow).
I reduced the spacers slightly as I was getting a bit of rubbing on the left front and just a hair on the left rear. All 4 corners seem optimal now.
Also got the bulk of the install done for the Racepak G2X GPS data acq system/dash. Just have to zip-tie and tidy things up tomorrow.
DRPHIL914
Feb 15 2014, 09:46 PM
After going to our local PCA chapter @ Bob Woodman's shop which included some good food, drink and many Porsche's , a nice tech session to prep for the next D.E. and track day, I went home and pulled the transmission, -
DRPHIL914
Feb 15 2014, 09:48 PM
Couple more
euro911
Feb 16 2014, 02:10 AM
How come there were no 914s in those pix, Phil
Speaking of 914s, I did some more stuff to the Westy
Made a bracket for a couple of communications antennas - will mount this on the roof rack between the solar panels ...
Click to view attachmentI found an empty auxiliary battery tray and a battery transfer module under the rear seat. Tidied up the electrical connections, tested the operation, then installed an Odyssey battery and a 1500-watt power inverter - 'while I was in there'
Click to view attachmentThe battery transfer modules automatically switches a charge between the main and auxiliary batteries. I will add another manual switch to charge the auxiliary battery from the solar panels when in the stationary mode.
Found a neat little cubby-hole behind the driver's seat too. Cleaned some debris out of it, carpeted it and installed a multi-band (HF/VHF/UHF) Amateur Radio in there. I'll remote-mount the display/control head to an appropriate location somewhere on the dash.
Click to view attachmentGonna take a drive in the 'BB' tomorrow ... I promise
DRPHIL914
Feb 16 2014, 06:25 AM
QUOTE(euro911 @ Feb 16 2014, 03:10 AM)
Steve
Feb 16 2014, 11:34 AM
QUOTE(euro911 @ Feb 16 2014, 12:10 AM)
Nice Mark!! I used to have a 2 meter rig in the glove compartment of my first 914 in the early 80's. I only have a multiband hand held now and an HF rig, that I need to connect back up someday. Too many hobby's and projects.
Steve
WA6YYE
orangecrate
Feb 16 2014, 10:31 PM
OMG I actually worked on it!!! After lots of
and
and
I was soooo burnt out from crawling under the damn thing I just left it alone for a couple months. Now I'm ready to put the seat mounts in so I started cleanin them up today. A slow restart but better than none at all. Way too long before I go
again.
computers4kids
Feb 17 2014, 09:47 AM
Mark,
Love solar...wired an entire roof of a cabin with panels (old style from an Arco field updated). If you put a hinge on one side of the Vanagon brackets, you could create an adjustable slide on the other to angle the panels when camped...makes a big difference. Great update.
JStroud
Feb 17 2014, 10:18 AM
Yesterday I loaded the white car and took it to McMarks shop in Sonoma, time to get the -6 engine mount welded in....an Original Customs mount.
Click to view attachmentToday I'm going to pull the clutch tube out of the parts car, there's a chance its not too rusted to reuse, we'll see. If nothing else it will give me a pattern to fabricate a new one.
But first, I have to take the wife to sacramento, looking at a new DD for her......a Subaru...
Jeff
euro911
Feb 17 2014, 12:22 PM
I may do that down the road, Mark. I built the racks on the roof of my house with hinges and adjustable telescopic struts (14 years ago) ... I believe I still have some spare hinges.
Click to view attachmentI need to do a lot to the Westy before it's March 20th ~ 23rd inaugural run to the 'Burning Ham-III' event., so this will have to do for now. The pop-top has about a 25° angle (?) when deployed ... I'll try to park with the nose pointed north this trip
Had to move the panels further out to accommodate the antenna bracket, so I removed them and made up the parallel wiring harness to size.
Click to view attachmentReinstalled the panels in their new position ... and the antenna bracket.
Click to view attachmentNext, gotta do all the cable runs (and eventually, a bath)
Checked out the fridge yesterday too ... it works great
chads74
Feb 17 2014, 02:10 PM
I came out of the gym and saw this little gem parked next to me.
Click to view attachment edit: Fixed pic
chads74
Stupid phone!
914_teener
Feb 17 2014, 02:51 PM
Drove it.
80 plus degree here....So Cal.... GMR was open and I saw a slew of cool cars coming down the hill.
Best was what looked like a early yellow Carrera followed by a late model yellow Vette.
Saluted as I went by......unbelievable weather out here. It is starting to worry.
You guys back East need us to get a little bit of your weather here.
Sorry no pics.....I was busy driving.
ClayPerrine
Feb 17 2014, 02:58 PM
QUOTE(Steve @ Feb 16 2014, 11:34 AM)
Steve
WA6YYE
I kept a 2meter rig in my 914 for years. Still have both the radio and the car, but not installed.
KC5HCV (The Hard Core Villain).
euro911
Feb 17 2014, 03:30 PM
Nice bus, Chad. I used to have a '67 back in the 70's
- went with the wasser-boxer this time, easier to do either a 2.2 Subi or a 1.8L TDI conversion down the road.
Hey, you let your license lapse, Clay
We're hoisting a UHF repeater about 1300 feet into the air with a 8 ft diameter helium balloon for the the Burning Ham-III event.
Last year's poster
Click to view attachmentDid Not drive the 'BB' yesterday as planned
- gonna take it for a spin today
- (if she starts up)
Mblizzard
Feb 17 2014, 09:18 PM
Started it finally. Bit of an epic fail on my part though. I pulled the gas tank to put in SS fuel lines and kinked a hose. Took a bit to figure that one out! Pulled the tank and instant fuel. Have to put it all back together now.
Alphaogre
Feb 18 2014, 11:59 AM
Got a good amount done this weekend!
Front trunk just about completed.
Got the glove box and radio back in with a new face plate of brushed aluminum.
Put Yellow tint on my headlights.
And got some new replacement projector fog lights, yellow tinted them and fabricated some mounts for them.
JawjaPorsche
Feb 18 2014, 12:10 PM
Sprayed my muffler with Rust-oleum High Heat paint. Drove it today for the first time in 10 days because of snow and crappy weather. Even took the top off!
Chris Pincetich
Feb 18 2014, 05:25 PM
I did my seasonal tire swap due to rains FINALLY settling in along the California Coast.
Off came the 205/50 Dunlop Star Spec Z1 summer tires
Bolted up the 195/65 Firestone M/S rated tires, and riding high again
AND drove from Pt Reyes to Marin Headlands, back home to Pt Reyes, then up to Tomales Pt and back!
dlee6204
Feb 18 2014, 05:55 PM
I installed a triad muffler on it this morning then proceeded to drive it to work. What a difference! I'm so much happier with the sound.
